My bongo is making a hisssing type noise
mblakeway
Post by mblakeway » Tue Mar 03, 2009 8:12 pm
Hello all
I have noticed that when the turbo kicks in there is a hissing type noise. It seems like its coming from the front end of the van, almost sounds like air is escaping somewhere. I dont know if anyone has had this before. I find that when the turbo kicks in the noise starts then as the turbo eases back down the noise goes. As I mentioned its like a hissing sound, like air leaking from a tyre. Sounds silly but not sure how else to describe it.
Any help is always appreciated. Is there a garage that deals in imports in the stevenage area as I would like some work to be done on the van.
Many thanks
Mark
Re: My bongo is making a hisssing type noise
Post by bigdaddycain » Tue Mar 03, 2009 8:14 pm
It's just the sound of the turbo spooling up, add a K&N to make it louder! :wink:
Post by missfixit70 » Tue Mar 03, 2009 8:17 pm
Check your seat clips are tightened down properly, may be time to "adjust" the bent spring section with a couple of hammer taps to tighten them up a bit :wink: Worked wonders with mine.
jaylee
Post by jaylee » Tue Mar 03, 2009 8:44 pm
I know it's been done before, but it's worth dragging out again..! #-o
Post by bigdaddycain » Tue Mar 03, 2009 9:18 pm
:lol: I'd forgotten about that jay... #-o :P
mblakeway
Post by mblakeway » Tue Mar 03, 2009 10:56 pm
Thanks for the information, will look into the seat clips.
Just sounds a bit louder than a normal turbo spinning up. As I said, its a bit like air leaking out of a tyre.
Jolly Rogers
Post by Jolly Rogers » Tue Mar 03, 2009 11:02 pm
You could always check your hoses. I had a similiar noise coming from my Bongo, it turned out to be a pinprick hole in one of my hoses.
Regor
Post by Regor » Tue Mar 03, 2009 11:18 pm
How about the snapped stud on the exhaust manifold syndrome :?:
Unless you've driven round a snake park lately :lol:
Hope you find out soon
cheffy34
Post by cheffy34 » Tue Mar 03, 2009 11:51 pm
bigdaddycain wrote:It's just the sound of the turbo spooling up, add a K&N to make it louder! :wink:
Trust you to like the turbo windup :wink: that is the one thing my puppy is missing :roll: suppose i will have to make do with the sound of 6 cylinders dancing :D
Dar
steviebongo
Post by steviebongo » Wed Mar 04, 2009 12:01 am
sounds like a possible leak on the boost side maybe an intercooler leak ,particuarly if it's when under load.
dandywarhol
Post by dandywarhol » Wed Mar 04, 2009 12:08 am
I'm with stevie - check all hoseclips from the turbo to the intercooler and out the intercooler to the inlet manifold - it's a long and winding road...................... :-({|=
mblakeway
Post by mblakeway » Wed Mar 04, 2009 12:09 am
where is the intercooler?
I will have a look at the hoses and stuff tomorrow, could you give me some advice on where to start!
I have checked the exhaust manifold, all ok on that side of things. The head was replaced a few months ago and all the fixings were changed, still I checked them today.
Thank you all
dandywarhol
Post by dandywarhol » Wed Mar 04, 2009 12:26 am
Intercooler behind the radiator - the 2 air ducts under the front bumper feed air to it.
Sounds like a loose clip to me - especially if the head was recently replaced - hope they haven't forgotten to tighten anything else :shock:
not so old
Post by not so old » Wed Mar 04, 2009 12:55 am
Sounds really daft, :roll: but it couldnt be your roof seals are damaged. We had this hissing for a while which got louder the faster we went and eventually turned into a squealing noise, it was then I realised it was the roof and the nice folk on here helped me diagnose it. small holes in the rubber seal was the cause and easily fixed. Probably something more Technie, but thought I'd mention it anyway
dom_e
Post by dom_e » Wed Mar 04, 2009 1:34 pm
I've read this thread with interest. We've got the same issue with ours - the hissing gets louder under load and is audable at about 65mph up a slight slope on a motorway for example. I'll also be checking hoses etc. soon!
I know our radiator was replaced by the last owner - any potential link? I have very limited knowledge on turbos, intercoolers etc, let along where they are on the Bongo :?
Beyond A to B
