Garage Bungled Installation of Low Coolant Alarm Help Needed
Re: Garage Bungled Installation of Low Coolant Alarm Help Needed
Post by francophile1947 » Thu Feb 26, 2009 6:22 pm
haydn callow wrote:And the winner of the BONGO TANK DIPSTICK is.............
Francophile1947..
Pm your address to claim your prize
Thanks Haydn, but I don't need one - I can actually see the fluid level through my tank =D> :lol: :lol:
westonwarrior
Post by westonwarrior » Thu Feb 26, 2009 10:29 pm
On the subject of coolant strength is too strong the problem or too weak?
haydn callow
Post by haydn callow » Thu Feb 26, 2009 10:37 pm
To weak.........you will get a long test "beep" and "muttering in very cold weather for the first couple of mins.
Not a big deal.
http://www.coolantalarm.co.uk
Also BMW Clocks
Post by bigdaddycain » Fri Feb 27, 2009 11:21 am
haydn callow wrote:If the alarm was flapping about there must have been a loose connection to cause it to play up...the module it'self is pretty bombproof
Thanks Haydn, you raise an interesting point, it sounds like the installer of the alarm hadn't done it properly, i'll relay the information on to the owner of the bongo in question. :wink:
Post by bigdaddycain » Sun Mar 01, 2009 1:23 am
New Forest Terrier wrote:Hooray!! :lol: Problem solved thanks to Haydn and everyone. :D The sender on the tank was slightly loose. :evil: Not obvious but a small amount of movement when twisted. Tightening the attatchment screw up cured the problem.
The Bongo has been tested on Hampshire's best potholes, various bends and a rough track and not a beep except for starting up. :D
The temperature readout really shows up how useless the guage is. The range that registers as 11 o'clock is very wide.
Congratulations everyone =D>
Glad it's sorted NFT :wink:
