NFT, only teasing about your suspension![]()
Garage Bungled Installation of Low Coolant Alarm Help Needed
- The Great Pretender
Re: Garage Bungled Installation of Low Coolant Alarm Help Needed
To infinity and beyond
- haydn callow
There is no way that sensor in the tank is becoming exposed with all that coolant.
I'm also wonderind about if it could be a bad connection now as there is a 4 sec delay which would make that unlikely. When you go round a corner and it beeps/flashes ...is it just a quick beep/flash and it is the RED led that flashes (the low water/coolant one ?)
we will get to the bottom of this.
I wonder where they have wired the pos feed from?
Your not coming Somerset way are you ??
- haydn callow
Just a idea.......there is a spare orange wire out the back of the display unit.....this is optional for a oil alert......if that is flapping about and touching earth that would be the problem...(no delay in that circuit)....the end should be taped up>>
where is the earth wire connection now..
Malc.
Malc.
- haydn callow
First to come up with the answer wins a BONGO COOLANT TANK DIP STICK
Through the coolant itself
- haydn callow
any more guesses ???
Aye,its a bummer......Send me my lollypop.haydn callow wrote:any more guesses ???
Is the coolant strong enough? I seem to recall an issue with somebody's alarm prematurely going off as the anti-freeze mixture was weak?
Is the actual alarm part flopping about? I heard of a member recently that tracked down repeated false alarms due to the alarm part rattling about all over the place, a ziptie cured it,though it should have been secured when it was fitted really...
- haydn callow
Hmmmm!! coolant strength can affect the alarm but not in this way....this is potholes and corners........coolant strength would be when cold and a "chattering noise......If the alarm was flapping about there must have been a loose connection to cause it to play up...the module it'self is pretty bombproof
New Forest Terrier
Hooray!!
Problem solved thanks to Haydn and everyone.
The sender on the tank was slightly loose.
Not obvious but a small amount of movement when twisted. Tightening the attatchment screw up cured the problem.
The Bongo has been tested on Hampshire's best potholes, various bends and a rough track and not a beep except for starting up.
The temperature readout really shows up how useless the guage is. The range that registers as 11 o'clock is very wide.
Congratulations everyone
The BewilderBeast - V6 Mean Green Tintop with LPG and 321 Away Montague Conversion
Great newsNew Forest Terrier wrote:Hooray!!Problem solved thanks to Haydn and everyone.
The Bongo has been tested on Hampshire's best potholes, various bends and a rough track and not a beep except for starting up.![]()
- haydn callow
Hmmm!!!not bad eh ?? smug look.haydn callow wrote:Well that's all fine...in fact if that tank is cold you could "suck" a bit out with a syringe.
Next...Is that terminal on the tank tight ?? You should not be able to revolve the terminal on the screw.
- haydn callow
And the winner of the BONGO TANK DIPSTICK is.............
Francophile1947..
Pm your address to claim your prize
Francophile1947..
New Forest Terrier
Smug look well deserved Haydn
. Perfectly diagnosed.
Found it first thing this morning but could not get to the pc until now to tell everyone.
Thanks Again
Thanks Again
