HI folks, we drove home last night with a horrible noise coming from the engine - on inspection I see that the bongo should have three fan belts but we only have two and a few tattered remains of one that runs from the alternator - the one nearest the alternator body.
engine temp stayed normal and we had no warning lights or reduction in steering or braking power. Big question, if any of you could help is what broke, what could we have done to the car and where can we get a new set of fan belts?
any suggestions would be most welcome
thanks
Shadow
oops...
- westonwarrior
Re: oops...
new fan belts can be got from the club shop or bongo bits etc
If yours is a diesel it take 2 fan belts and an aircon belt so my guess would be its a fan belt.
If it were me Id change them all ( as I'm lazy and don't like doing jobs more than I have too)
Re: oops...
thanks for that - what does that belt run? could we have done anything nasty to the car?
sorry to be a pain -
Shadow
Shadow
- missfixit70
Re: oops...
If it's one the pair of belts that drive the alternator & waterpump, as long as T'other one is still doing it's job, it' should be ok, but change at least the pair asap, if not the ac one aswell as Rob says.
Re: oops...
thanks
Re: oops...
Should definatley be replaced as a pair.
Good luck.
Good luck.
- dandywarhol
Re: oops...
Check the crankshaft pulley for security in case it caused the breakage
Thread here
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=28389
Thread here
