does your horn need to work to pass a mot
stansyerman
Post by stansyerman » Mon Feb 09, 2009 6:57 pm
does your horn need to work to pass a mot change the fuse and still nothing what should i check next mot on wednesday
jaylee
Re: does your horn need to work to pass a mot
Post by jaylee » Mon Feb 09, 2009 6:59 pm
Yes..
Have you tried the relay..?
teenmal
Post by teenmal » Mon Feb 09, 2009 7:05 pm
stansyerman wrote:does your horn need to work to pass a mot change the fuse and still nothing what should i check next mot on wednesday
Hi Stan,the horn/horns are part of the MOT.The Bongo has normaly two horns High and Low.check for voltage at the horn when the push button is activated.
Ps the volume of the horn/s are also part of the test.
Cheers Malc.
stansyerman
Post by stansyerman » Mon Feb 09, 2009 7:54 pm
how do i check the relay
stansyerman
Post by stansyerman » Mon Feb 09, 2009 7:59 pm
where is the horn cant find it
Post by francophile1947 » Mon Feb 09, 2009 8:01 pm
You have to remove the nearside headlamp to get to the horn.
scanner
Post by scanner » Mon Feb 09, 2009 8:02 pm
Cheers Malc.
It normally has just one horn.
Post by Muzorewa » Mon Feb 09, 2009 8:08 pm
francophile1947 wrote:You have to remove the nearside headlamp to get to the horn.
Offside, surely? :?
Post by francophile1947 » Mon Feb 09, 2009 8:09 pm
Offside, surely? :?
Ooops :oops: :oops: :oops:
stansyerman
Post by stansyerman » Mon Feb 09, 2009 8:14 pm
if your looking at the front of the bongo is that left of right light
teenmal
Post by teenmal » Mon Feb 09, 2009 8:14 pm
Offside, surely? :?
http://www.lushprojects.com/bongoparts/ ... tches.html
Post by francophile1947 » Mon Feb 09, 2009 8:15 pm
stansyerman wrote:if your looking at the front of the bongo is that left of right light
Left
Post by bigdaddycain » Mon Feb 09, 2009 9:19 pm
Two on this 2000 model bongo....
I think my "95" has just the one, but i can't remember which side :(
scanner
Post by scanner » Mon Feb 09, 2009 9:21 pm
#2 must have arrived with the facelift - mine is '98 "R" and has (had) just one on the drivers side.
maxheadroom
Post by maxheadroom » Mon Feb 09, 2009 9:22 pm
bigdaddycain wrote: I think my "95" has just the one, but i can't remember which side :(
Left as you look at it from the front and right if you look from the back :roll:
Keep the Faith
