Changing back bench seats?
changeinminds
Post by changeinminds » Sat Jan 24, 2009 10:45 pm
Hi all Im new here as I just bought my first bongo yesterday, so nice to meet you all!!
Im wondering wether, the back bench seats can be changed to a pair of split fold up ones and if so any Ideas on where I get them and How I do it ???
Cheers for any Help. :D
Peg leg Pete
Re: Changing back bench seats?
Post by Peg leg Pete » Sat Jan 24, 2009 10:48 pm
Welcome :) someone will be along soon to answer your question :wink:
Image Pete
steviebongo
Post by steviebongo » Sat Jan 24, 2009 10:51 pm
welcome to the forum, for what reason do you want the split seats?
cheers.
99 new shape 2 tone silver2wd aft
changeinminds
Post by changeinminds » Sat Jan 24, 2009 11:04 pm
Even tho Im off the tools now, Im a chippy by trade and would like a bit more room in back at times. Also from what I've seen you can put a sink unit etc on one side, if I wanted to in the future.
Harry
Post by Harry » Sat Jan 24, 2009 11:09 pm
From previous posts I gather that the brackets for the rear fold up seats are not present on those vans fitted with bench seats. Also you would have to cut holes through the side panels and get a welder to fix the brackets.
Forum member Madmile is down your way and he converts bongo so he will know the full story.
Depending on how many seats you need have you thought of reversing the front bench seat and 'converting' the rear bench seat into a kitchen unit utilising the seat base and runners?
good luck
H 8)
http://watcherswildlife.co.uk
steviebongo
Post by steviebongo » Sat Jan 24, 2009 11:11 pm
if your thinking of putting in a kitchen unit you can also fit it behind the o/s/f seat,then you dont have to lose any seating or bed space?
changeinminds
Post by changeinminds » Sat Jan 24, 2009 11:22 pm
Pardon my ignorance guys, Im sure I could do these type of things your talking about but Im unclear on a few things.
o/s/f ???? If I put the unit behind bench seat do they need to be pushed right forward?
If I reversed the front bench seats and used the base and runners, what exactly would I be utilising them for?
Would it be the base of kitchen unit??
steviebongo
Post by steviebongo » Sat Jan 24, 2009 11:28 pm
sorry for the trade lingo o/s/f is the drivers side front, and you push the 2 bench seats right back thus enabling for the fitment of a kitchen unit like the 1 that campers scotland does.hope this helps .
cheers.
99 new shape 2 tone silver 2wd aft
changeinminds
Post by changeinminds » Sat Jan 24, 2009 11:35 pm
yea cheers that makes more sense, are there any pics from Campers scotland on here.
madmile
Post by madmile » Sat Jan 24, 2009 11:43 pm
Quite often people put a conversion across the rear of the bongo, and with twin bench seats, you could retain 6 seats in the rear plus some sort of conversion. I dont personally like these as it puts all the additional weight behind the rear axle, and makes the steering a bit light (the bongo is not a load lugger van).
If you want a corner kitchen, then its quite possible, but you obviously have to lose an entire bench and therefore become a 5 seater.
Fitting split seats is quite a big job and requires some precision fabrication onto the rear arches. If you want to try it, I could supply you seats, but would not personally take on such a job.
I can however see the popularity of split rear seat bongos - they definitely are more flexible for carrying loads.
steviebongo
Post by steviebongo » Sat Jan 24, 2009 11:43 pm
sorry but don't think so but here the is the web site, hope it gives you some ideas.www.campers-scotland.com
changeinminds
Post by changeinminds » Sat Jan 24, 2009 11:51 pm
Cheers, just check out your web site, madmile, very neat conversions, you obviously know what your doing, didnt catch where you were based?
cheers stevie Ill check it out now
madmile
Post by madmile » Sat Jan 24, 2009 11:55 pm
Based near Caerphilly (bedwas).
Were you at Aberavon today?
changeinminds
Post by changeinminds » Sat Jan 24, 2009 11:58 pm
yep, I assume I parked up next to u mate.
madmile
Post by madmile » Sun Jan 25, 2009 12:02 am
I thought that may have been you - sorry I didnt say hello properly. Looked a nice van.
Hoping to go again tommorrow if the rain holds off and the wind plays ball [-o< .
