Just after Christmas, I noticed that I couldn't go above 3000 revs, which was annoying, but not undrivable.
Now, it has reduced to 2000 revs, which is no good.
My local garage says he thinks it is the fuel pump which is acting like a governor, and only supplying a restricted supply of fuel.
Are there any common problems or can anybody point me in the right direction?
Thanks in anticipation,
John.
Fuel Problem
Re: Fuel Problem
Welcome to the madhouse
- don't forget to put your location in your profile as somebody local may be able to help.
Common causes of your symptoms are a blocked fuel filter, blocked strainer in the banjo union to the fuel pump and leaking O rings in the fuel pump (are there any signs of a fuel leak behind the pump?)
If you have the Winter version of the Bongo (it'll have 2 batteries if you have), it could be a stuck valve in the exhaust, or you could just have caught the switch with a picture of an engine on it.
Re: Fuel Problem
I think Franco has covered main options to try, except not sure about leaky O rings as I had tthose and it didn't cause any performance change (just a slow drip of diesel, and you'd soon know if it was more). Other possibilities (based on what I've read on here, but I'm no expert):
- Blocked air filter or intake (people have had things go/get stuck down the intake under the bonnet)
- Turbocharger problems
- Throttle Positon Sensor faulty (I'm not actually sure this is relevant but have a search and read up)
Good luck - keep us posted
Re: Fuel Problem
Neither am I Mike - I just seem to remember someone with a bad leak was drawing air in - probably total rubbishmikeonb4c wrote:I think Franco has covered main options to try, except not sure about leaky O rings as I had tthose and it didn't cause any performance change (just a slow drip of diesel, and you'd soon know if it was more).
Re: Fuel Problem
Ah! You could have a point there - hadn't thought of that.francophile1947 wrote:Neither am I Mike - I just seem to remember someone with a bad leak was drawing air in - probably total rubbishmikeonb4c wrote:I think Franco has covered main options to try, except not sure about leaky O rings as I had tthose and it didn't cause any performance change (just a slow drip of diesel, and you'd soon know if it was more).![]()
- The Great Pretender
Re: Fuel Problem
To draw air if it is from the pump it will be from the front seal (behind the drive belt) as this is where the pump produces negative pressure (sucks the fuel in).mikeonb4c wrote:Ah! You could have a point there - hadn't thought of that.francophile1947 wrote:Neither am I Mike - I just seem to remember someone with a bad leak was drawing air in - probably total rubbishmikeonb4c wrote:I think Franco has covered main options to try, except not sure about leaky O rings as I had tthose and it didn't cause any performance change (just a slow drip of diesel, and you'd soon know if it was more).![]()
OK add that one in then I reckon
All other connections from there to the tank could also 'suck' in air as the whole line is negative.
To infinity and beyond
Re: Fuel Problem
If i understood it correctly, the leaking pump was quite severe, i know fuel pressures are pretty high with turbo diesels, and a significant leak could cause insufficient fuel pressure to atomise the fuel correctly at the injectors...or summat else might be broke.
