fault code reading...
joe-robo
Post by joe-robo » Mon Jan 12, 2009 1:06 am
looked on the fact sheet about code reading, to me the picture isn't a hundred percent clear which pin sockets need to be bridged. can someone please confirm which they are before i go and stick some wires in!!!...
also, i take it by the shape of the plug that it's not OBD II compatable???
dandywarhol
Re: code reading...
Post by dandywarhol » Mon Jan 12, 2009 1:21 am
You're right - its not OBD compliant - pins are "TAT" terminal to ground for automatics and "TEN" terminal for manuals. This should set the HOLD light into a sequence of flashes as per the factsheet.
Fault codes can be erased by using the footbrake :D
Re: code reading...
Post by bigdaddycain » Mon Jan 12, 2009 8:57 pm
Really?.... Elaborate al.... [-o<
dandywarhol
Re: fault code reading...
Post by dandywarhol » Mon Jan 12, 2009 9:03 pm
In the factsheet :wink:
joe-robo
Post by joe-robo » Thu Jan 15, 2009 12:05 am
thanks for that, i cant se no mention in the fact sheet about the brake peddle?...
dandywarhol
Post by dandywarhol » Thu Jan 15, 2009 12:41 am
From the factsheet............dunno which one you're reading...........=D> :roll: I guess thats why the brake lights work independantly from the ignition
Automatic vehicles:
Remove the wire from the negative terminals for at least 20 seconds.
Click on the brake pedal and release.
Re-connect negative battery terminal.
Start engine, and run for 3 minutes at 2,000 rpm idle.
Check all fault codes have cleared.
From the workshop manual for manual gearbox vehicles:
Keep turning the idle (I think they mean ign.) switch ON and OFF for more than 5 seconds while short circuiting the test terminal and delete the memory of the service code.
joe-robo
Post by joe-robo » Thu Jan 15, 2009 5:44 pm
the fact sheets i'm reading are titled 'transmission fault codes' and 'hold light'
just re read these two.... no mention, i must be missing the fact sheet, which one is it?....
dandywarhol
Post by dandywarhol » Thu Jan 15, 2009 7:06 pm
Diagnostics :)
joe-robo
Post by joe-robo » Thu Jan 15, 2009 11:35 pm
HELLO how blind am i????....LOL... cheers dude, that makes everything clear.... thanks again
