Steam out of exhaust! can these prices be right?
Veg_Ian
Re: Steam out of exhaust! can these prices be right?
Post by Veg_Ian » Fri Jan 09, 2009 10:27 am
An inspiration to us all - well done Tom!
haydn callow
Post by haydn callow » Fri Jan 09, 2009 11:02 am
Oldgit......well impressed......was the head complete or did you have to swap valves etc....10/10...go to the top of the class and have a gold star.
http://www.coolantalarm.co.uk
Also BMW Clocks
oldgit
Post by oldgit » Fri Jan 09, 2009 11:38 am
No, the head wasn't complete. as all the components were all in good condition, I ground the valves in to the new head, and then replaced it, I had a lot of help from Doone and Allan, thanks again. The worst problem was getting it started when I'd finished, that horrible little filter in the pump, kept blocking up. I am now am an expert of cleaning the fuel system.
Post by mikeonb4c » Fri Jan 09, 2009 1:41 pm
oldgit wrote:I had the same problem with our Bongo, cost £1200 at a local garage to have fixed turned out to be Cowboys ,lasted about 6 months, they refused to admit liability. Finally did the job myself, replaced the head, cost about £300, bought the other parts from Bongo bits. In total cost me about £450. I really gave the Rad a blitzing, replaced all the hoses, and the Bongo has been running perfectly for nearly a year now. I had a lot of invaluable help from this forum, and couldn't have managed withou all the helpful advice. I am no Spring Chicken so if I can do it with the help of the Bongo manual, I'm sure anybody with a bit of practical knowledge can do the same. Cheers Tom
Excellent post Tom and sorry I forgot to include you in the list of successes (ageing brain I fear). The more I read of this the more I think it sounds like a worthwhile option to do it yourself. Once the central console gubbins has been (easily) removed, am I right in saying the head is easily accessible for working on? Good access is a major factor I think in achieving a successful outcome (esp. for those of us with bad backs) as you can then focus well on the job in hand.
Do I recall you having some starting problems, and were they after doing that job? It would be useful to have a reminder of cause and solution in case our current case-owner would benefit from reading it. 8)
Post by Doone » Fri Jan 09, 2009 11:09 pm
No worries Tom, it was worth all your effort in the end. :D 12 months later it's still going strong...so Allan said to let you know that he's saving all the blocked filter jobs for you...if you're ever down this way. :wink:
nigelginny
Post by nigelginny » Fri Jan 09, 2009 11:21 pm
Just had ours repaired, new head, head set and coolant switch, coolant etc 1500 quid :cry: shes worth it
Post by mikeonb4c » Sat Jan 10, 2009 12:23 am
nigelginny wrote:Just had ours repaired, new head, head set and coolant switch, coolant etc 1500 quid :cry: shes worth it
Absolutely. Draw a line and move on....in the Bongo of course. I just love mine to bits, and all cars can thrown big bills. Now have you got that low coolant alarm fitted? :lol: :lol: :lol:
