I have a small diesel leak from the 'dome' area of my injector pump and wish to replace the o rings.
I saw a post on the forum a while ago showing how to do it with pictures and all but cant seem to find it now i need it!?
I also have no idea where to get the 'O' rings from OR which ones to get.
If anyone reads this topic and has fitted the NGK heater plugs could you let me know which ones to get please.
Cheers,
Lloydy
Where do i get 'O' rings for fuel pump from?
Re: Where do i get 'O' rings for fuel pump from?
PM Dandywarhol for a supplier who can post them, if the PDF file doesn't advise you.
Supplier for seals.teenmal wrote:http://www.igmaynard.co.uk/bongo/member ... elpump.pdf
http://www.lawsondiesel.co.uk
About £5.00 inc p&p
Cheers all,
- missfixit70
If you look in the compatible parts database at the top of the techie section it should have the plugs there.
NGK glow plugs are Y701J.
I got mine from http://www.glow-plugs.co.uk/
Mazda Bongo is not listed but if you search on the Ford Ranger it will take you to the correct plugs.
They are shown as £7.59 plus VAT each.
1995 N reg 2WD AFT in green/grey
www.whiteroseancestry.co.uk
