Heres a link to the kit:
http://www.moss-europe.co.uk/Shop/ViewP ... ortOrder=1
You can buy the bulbs from Halfords, however, don't buy the cheap ones as the dim pattern isn't as good as the branded bulbs.
Also totally illegal for road useMiles69 wrote:Hi, have you thought about uprating your wiring and bulbs to 100w/80w? You can buy a relay and wiring loom kit from Moss Europe for £50 and then buy the high wattage bulbs in safety. This will really make a difference to your lighting. I used one of the kits on my old impreza and the difference was amazing.The kits takes the power feed straight from the battery so it places no additonal current loads on the switches or nongo wiring loom. I'm going to fit the kit on to our bongo as my wife keeps complaining about the poor light pattern. Its easy to fit and much better than fitting spots or fogs.
it was also said on here long ago that this could be dodgy, heatwise, as Bongo light covers are plastic not glass.Miles69 wrote:Hi, have you thought about uprating your wiring and bulbs to 100w/80w? You can buy a relay and wiring loom kit from Moss Europe for £50 and then buy the high wattage bulbs in safety. This will really make a difference to your lighting. I used one of the kits on my old impreza and the difference was amazing.The kits takes the power feed straight from the battery so it places no additonal current loads on the switches or nongo wiring loom. I'm going to fit the kit on to our bongo as my wife keeps complaining about the poor light pattern. Its easy to fit and much better than fitting spots or fogs.
I think you've summed it up pretty well. In my case, the 100W spots are set at a decent angle of declination, are wired to work on main beam, and - just as with main beam itself, are extinguished as soon as oncoming traffic is in sight. But I accept they are technically in breach of the legal rating (itself a bit arbitrary I'd suggest as - depending on how the reflectors focus the beam, the illumination / candella power and thus ability to dazzle could be higher with a lower rated bulb than with a higher one).Miles69 wrote:Yes, legally you are right, you will be committing an offence in the UK, it’s a weak argument as how many people do you see driving round with their fog lights on when it isn’t foggy – this is also illegal but I’ve never heard of anyone being prosecuted for it.
Provided that your headlights are correctly aligned then you will not have a problem and you won’t be prosecuted – My car has always passed the mot and even passed an informal road inspection by the police when I got pulled over for speeding. There are no “poseur” points for having correctly aligned headlights – unlike driving around with your fog lights on in perfect visibility or having 100W spot lights which blind on coming traffic…
In reality an 80w dip beam will only be a bright as the new generation of HID lights that are now fitted to most new cars.
You have nowMiles69 wrote:Yes, legally you are right, you will be committing an offence in the UK, it’s a weak argument as how many people do you see driving round with their fog lights on when it isn’t foggy – this is also illegal but I’ve never heard of anyone being prosecuted for it.
This forum is amazing. Where else would I have found that rare occurence of someone who got done for spotlights (do I recall you mentioning this at the time France or is my faulty memory at work again?). Was the 'pull' because they saw you driving with them on. Did they get involved in checking that the bulbs were ratings compliant and if so, how did they manage to ascertain the wattage?francophile1947 wrote:You have nowMiles69 wrote:Yes, legally you are right, you will be committing an offence in the UK, it’s a weak argument as how many people do you see driving round with their fog lights on when it isn’t foggy – this is also illegal but I’ve never heard of anyone being prosecuted for it.I didn't even realise I had them on (bulb in warning light had failed and I must have hit the switch
). The local police were having a campaign against faulty/illegal lights at the time.
Yup, I know. I was waiting - no pun intended - for someone to spot that. It was my roundabout way of returning the debate to the delicate issue of whether it matters having illegal bulbs in your lights. You see, I think it is the general point that Miles69 makes, and that Franco is confirming with his last post, that is the key I think. Unless you prod the bees nest with a stick (as when being collectively careless in having ill fitted lights that dazzle drivers, driving with one out etc. etc.) then it is unlikely they will swarm all over you. Even when they do, they are more likely to give you a ticking off than pursue you through the courts (do bees do that?.missfixit70 wrote:Franco got done for foglights Mike, not spotlights
As you've said Mike, the 100W are a lot brighter than standard ones. They checked all the lights on mine and I'm sure an experienced copper would enquire as to why yours were so bright. Also, as David said, you could well invalidate your insurance in the event of a claim.mikeonb4c wrote:PS - also implied in Francos post I think is that it is unlikely, in the absence of a larger sticker saying 'these bulbs are 100W' that the police will have a ready way of knowing what wattage they are
