cigarette lighter
susan
cigarette lighter
Post by susan » Thu Dec 18, 2008 6:54 pm
Does anyone know how i can get my lighter out off the socket as it seems to of got stuck :oops:
technophobe
Re: cigarette lighter
Post by technophobe » Thu Dec 18, 2008 7:15 pm
Probably rust. WD40.
Richard & Jo
Post by mikeonb4c » Thu Dec 18, 2008 11:19 pm
Search ebay for 'Bongo pliers'. Sorry - couldn't resist it! Can't think what sensible advice to give except try this and try that. Ultimately, drill a small hole in the middle and screw in a self tapper so you can pull on it. :roll:
teenmal
Post by teenmal » Thu Dec 18, 2008 11:27 pm
technophobe wrote:Probably rust. WD40.
WD40 [-X only use the none flammable type on a lighter. [-o<
Post by missfixit70 » Thu Dec 18, 2008 11:49 pm
disconnect the termnials behind & see if you can remove the whole assembly, i think it's 2 squeeze in type clips behind the panel that hold it in, so it may not work with the lighter stuck in. can you rotate the lighter in the socket?, if the socket turns with it grip it from behind, it may free it up.
cheffy34
Post by cheffy34 » Fri Dec 19, 2008 12:27 am
Front or rear , Front is a pain, can't imagine it with the lighter stuck in :shock: I hate fiddley things, i do fiddley at work :| Take it out by pushing, pinching and twisting from behind :? :D then bin it and put an after market one in, cost me £4 i think, not orig but works and doesn't blow the fuse when i need to use it :roll: mine got stuck once and it kinda, kept blowing the fuse after, don't think it was even orig lighter to socket if ya get me :? My back one is goin on the list on the basis it likes to work when it feels like it #-o and i can have one i can find in the dark :D reckon mine was owned by a smoker prev
cheffy34
Post by cheffy34 » Fri Dec 19, 2008 12:29 am
PS
leave out the wd40 :wink:
