-When camping away from a power hook up (i.e. using leisure battery only) what is the best way to heat your Bongo without running the engine or running the battery down in 10 minutes flat? How long would a 12v fan heater run from a 85amp leisure battery? Is there a better way?
-I would like to install a 110v hook up for when im at camp sites or have power to hand. What kit do i need to convert the 110v to 240v so i can run oil filled heaters and tv’s etc?
Have read lots about Zig units. Can i get one that will monitor my batteries and sort out the problem of 110v hook up?
Dan
