V6 owners
manners
V6 owners
Post by manners » Mon Dec 15, 2008 8:40 pm
Found this on Ebay USA http://cgi.ebay.com/ebaymotors/1990-199 ... ccessories
Matches lush project for part numbers and would cost £307 for the pulleys and £80 for the belt from UK suppliers rip of Britain strikes again :evil:
Simon Jones
Re: V6 owners
Post by Simon Jones » Mon Dec 15, 2008 8:52 pm
It says it's compatible with '1990-1995 Mazda 929 3.0 DOHC 24V JE27, 48, 74' - is that the same as the 2.5 version used from 1995 onwards? If it is, then it would be worth you getting a few owners to club together & place an order.
manners
Re: V6 owners
Post by manners » Mon Dec 15, 2008 9:12 pm
Simon Jones wrote:It says it's compatible with '1990-1995 Mazda 929 3.0 DOHC 24V JE27, 48, 74' - is that the same as the 2.5 version used from 1995 onwards? If it is, then it would be worth you getting a few owners to club together & place an order.
The part numbers match with lush project.
hogggman
Re: V6 owners
Post by hogggman » Mon Dec 15, 2008 9:24 pm
i`ve often looked on ebay usa at mazda 929 stuff,but didn`t know what 3.0 stuff would be compatible with the 2.5.i remember someone buying a mazda 929 manual and it only having info on the 3 litre,and they concluded that it was no use to them.i assumed that the 3.0 engine would be bigger,and therefore slightly longer timing belt,or is the extra .5 litre achieved by larger bore or longer stroke?
jamie
p.s i don`t really know what i`m talking about........................... :oops:
dandywarhol
Re: V6 owners
Post by dandywarhol » Tue Dec 16, 2008 1:13 am
The idler bearings are certainly the same number but not so sure about the belt - a different prefix. It could be a different length on the 3 litre :?
maxheadroom
Re: V6 owners
Post by maxheadroom » Tue Dec 16, 2008 7:54 am
Keep the Faith
cheffy34
Re: V6 owners
Post by cheffy34 » Tue Dec 16, 2008 9:45 am
cheffy34 wrote:If it fits what a saving, i've seen the hydraulic tensioner alone double that :shock: one of my bearings is a bit dry on start up :roll: MMMMMMMMMMMMMMMMMMMMMMMMM :!: deffo worth investigating thanx :wink: :wink:
