While fitting a willinton LB kit for Vicky007 yesterday, I noticed the fan was completely siezed
took it out, it was full of water & the shaft was completely siezed on the bearing, eventually got it freed up, cleaned out & rebuilt, worked ok, checked the resistor pack (manual ac) middle one had popped, soldered it back, all worked ok, fan was blasting out. It'll be interesting to see how long it lasts though. I drilled a tiny hole in the bottom of the motor casing & enlarged the drain hole in the plastic casing below as it was too small & had blocked with little bits of crud.
Of course the middle drain hole under the windscreen was blocked
Good tip on the LB tray mounting bracket Dave - unfortunately I hadnt followed it & had already fitted it all in
