Location of Electric blind switches
stilldesperate
Post by stilldesperate » Thu Dec 11, 2008 5:54 pm
Hi all,
The new Bongo looks to have electric blinds, but i can't locate the operating switch/s. :?
I understand the wiring loom could go to the blanked off switch bank to the left of the steering wheel - where is the rear location for the switches (manual has drawings, but I can't locate them).
Is it possible that the blinds are fitted, but there's no switches? :?
Thanks, S.D.
"The older I get, the faster I was"
manners
Re: Location of Electric blidd switches
Post by manners » Thu Dec 11, 2008 6:07 pm
Not all Bongos have electric blinds.
daveblueozzie
Post by daveblueozzie » Thu Dec 11, 2008 6:08 pm
not all bongos have electric blinds. mine does not have leccy blinds or leccy mirrors, but it is a FORD not a MAZDA.
Lost without my Bongo.
mister munkey
Re: Location of Electric blind switches
Post by mister munkey » Thu Dec 11, 2008 6:18 pm
Theres also the front contol switches to the lower left of the steering column
If they're not there, it sounds like yours are manual.
New Forest Terrier
Post by New Forest Terrier » Thu Dec 11, 2008 6:35 pm
Mine has two sets of switches for the blinds. Front ones are in the bottom panel on the left, by the ciggie lighter. This is below the other panel of blanked off switches. :?:
The second sets are by each window. Below three windows and set into the plastic side panels with the fourth above the sliding door. Gives bored passengers some entertainment.
This a 95 V6.
Regards
Mary
The BewilderBeast - V6 Mean Green Tintop with LPG and 321 Away Montague Conversion
stilldesperate
Post by stilldesperate » Thu Dec 11, 2008 7:08 pm
Thanks all,
Was looking in the dark - got a torch on the job - the blinds are manual :oops: , (the ones I'd looked at had retracted up into the top too far, a bit of poking about sorted it!)
Two years without a Bongo was two years too long - can't wait to get it registered!
Post by bigdaddycain » Sun Dec 14, 2008 11:45 am
If you look really carefully at the grey plastic trim above the sliding door, you can just make out the cut-out impression where the switch for that particular blind would live.
