Dar
ps the damn sensor cost 90 odd squids not inpressed if i have to get another one
Only if i chop off four of mine!cheffy34 wrote:
ANYONE HAVE SIX FINGERS![]()
bigdaddycain wrote:I'm VERY surprized the dizzy took on water like that, i'm even more surprized that it isn't electronic injection! I always assumed that the v6 had leccy injection... (i know what they say about assumption)...![]()
Sellophane bag with holes for the leads, tape the holes up afterwards. Treat the dizzy/air filter as you would were you to jetwash the engine....
I think bigdaddycain means "Distributerless Ignition", i.e. 1 coil per 2 cylinders, or later cars 1 coil per spark plug (No damp problems).dandywarhol wrote:bigdaddycain wrote:I'm VERY surprized the dizzy took on water like that, i'm even more surprized that it isn't electronic injection! I always assumed that the v6 had leccy injection... (i know what they say about assumption)...![]()
Don't understand this bit of wisdom Ste - they do have multipoint injection but still need something to distribute a spark to ignite the fuel........................
There is a notion niggling at the back of my mind telling me that sudden heat change, i.e. drenching a hot lambda probe in cold water, can in fact kill it...![]()
Is it located on the manifold, or the downpipe? Are you sure that any heat shields/splash guards are in place?
