Battery tester for leisure battery.
Re: Battery tester for leisure battery.
Post by missfixit70 » Fri Dec 12, 2008 3:53 pm
I can't see any mention of 9 volts on the ebay description & specs :? Only on the title.
If the operating range 5 to 15v is what is displayed - then what is the measured range 0 to 20v?
teenmal
Post by teenmal » Fri Dec 12, 2008 4:04 pm
missfixit70 wrote:I can't see any mention of 9 volts on the ebay description & specs :? Only on the title.
Not sure what they mean by 0 to 20v,can only think they mean 0 volts to minus -20volts.This gauge is probably for testing other than a battery.ie on transformers etc.
Cheers Mal..
Post by missfixit70 » Fri Dec 12, 2008 4:19 pm
Sorry but I think you're wrong, why would it have an operating range of 5 to 15v & a measured range of 0 to 20v (+ or -), if it did not mean it operated on 5 to 15v & measured 0 to 20v? #-o
dandywarhol
Post by dandywarhol » Fri Dec 12, 2008 6:03 pm
I also read it as an operating (input) range from 5 - 15 volts, presumably to operate the unit and backlight - therefore my info on wiring it through the ignition still stands...........
Post by mikeonb4c » Fri Dec 12, 2008 6:43 pm
There's only one way to settle this:
Fffffffiiiiigggggghhhhhhhtttttttt!
:lol: :lol: :lol:
Post by missfixit70 » Fri Dec 12, 2008 6:49 pm
Not on this friendly forum Mike [-X :lol:
stringman
Post by stringman » Fri Dec 12, 2008 6:53 pm
Having had a better look at the specifications I would say that Kirsty and Dandy are spot on.
The voltmeter side can be wired to the leisure battery and the other input which it says cannot be wired to the measured circuit would be ideal connected to an ignition feed and therefore the other battery. It clearly states that this feed can be 5 to 15 volts (you'll probably find that the higher the voltage the brighter it will be!)
Good luck :wink:
Steve (auto electrician for the last 15 years!)
Tin top Bongo camper, Peugeot Partner Combi, Kawasaki ZRX1100, Yamaha SR250SE
daveblueozzie
Post by daveblueozzie » Fri Dec 12, 2008 7:18 pm
WILL HAVE A GO SAT/SUN, if it does not work (i dunno why it wont) i will only have lost about £8 and a bit of time.have read the info on his ebay site and it looks like anything from 5 to 15 v for the main power is ok.
have read all your comments and info and i think swiched live wire is the way to go.
Kirsty, yes we used the patches by taking the fuses out so a good source of power for the display.
Lost without my Bongo.
Manny
Post by Manny » Fri Dec 12, 2008 7:36 pm
If the device is wired to read the leisure battery voltage and connected to the Start battery for its supply because it needs a separate power source, when the split charge relay is turned on the two batteries are electrically connected together. Won't this matter?
Manny
A Bongo by any other name would still drive as sweet.
teenmal
Post by teenmal » Fri Dec 12, 2008 7:51 pm
Manny wrote:If the device is wired to read the leisure battery voltage and connected to the Start battery for its supply because it needs a separate power source, when the split charge relay is turned on the two batteries are electrically connected together. Won't this matter?
Manny
You are correct Manny the unit would be drawing from the same source.
Ps I have a sneakey feeling that the back light should be 5 Volts not 9 Volts.
Post by missfixit70 » Fri Dec 12, 2008 8:02 pm
These are the instructions for the one I got, hope it helps clear things up :wink:
http://www.e3b6a5y.com/2006/WiringDiagr ... 000Vdc.jpg
teenmal
Post by teenmal » Fri Dec 12, 2008 8:43 pm
missfixit70 wrote:These are the instructions for the one I got, hope it helps clear things up :wink:
Hi Kirsty,that one looks good,it seems to have a built in regulator 5V to 15V,therfore it can be powered from the same source.Its Daves that is the problem,I dont think it has this feature.
Cheers Mal..
Post by missfixit70 » Fri Dec 12, 2008 8:50 pm
Even though it says 5 - 15v operating range? The same as mine did when I bought it.
teenmal
Post by teenmal » Fri Dec 12, 2008 9:05 pm
missfixit70 wrote:Even though it says 5 - 15v operating range? The same as mine did when I bought it.
I can remember you buying it,I think you said you got it for £8.00.If it is what it says on the tin its a good buy.
Just going for a pint with 4 mates 2 mechanics an auto elecy and a Dobber.
Cheers Mal..
daveblueozzie
Post by daveblueozzie » Fri Dec 12, 2008 9:19 pm
ok you guys and gals you have put the cat amongst the pigeons :lol:
Kirsty that is not the same unit as mine, mine does not have dip switches #-o
Manny you may be correct when the split charge switches on it will read what the main battery/alternator is putting into the LB. but am correct in assuming that it is a one way feed so it will not be reading the main battery ,only what the split charge is putting in.
