top hose help
top hose help
our top hose between engine and radiator has split and we need a new one. Our garage can't get one. Does anyone know were we can get one or if there is an appropriate alternative from another car we can use/
Bit stuck so any help would be gratefully received.
Thank you.
Thank you.
Re: top hose help
Just search on "flippa" and "hoses" and you'll find a link to member flippa's shop where he sells silicone ones for less than the cost of ordinary original ones.
Re: top hose help
Here. http://www.mazdabongo.com/display.products.php?cId=91
Here. http://cgi.ebay.co.uk/MAZDA-BONGO-SILIC ... 6004r14059
Or here. http://www.bongobits.com/Main.asp?PageN ... t=3&Page=8
- haydn callow
Re: top hose help
The Bongo has 2 top hoses...one runs from the Rad to the metal pipe (under the bonnet) and the other from the "other" end of the metal pipe to the engine (under drivers seat)
Re: top hose help
You will find them here or on ebay.Just search on "flippa" and "hoses" and you'll find a link to member flippa's shop where he sells silicone ones for less than the cost of ordinary original ones.
http://www.siliconehosestore.co.uk/
Re: top hose help
thanks folks - its the hose between the engine and the rad - need to get a move onas I need the bongo for Christmas.
Thanks again - brilliant.
- dandywarhol
Re: top hose help
As Haydn says above - which hose? there's 2
- haydn callow
Re: top hose help
shadow wrote:thanks folks - its the hose between the engine and the rad - need to get a move onas I need the bongo for Christmas.
There is not a hose from the engine to the rad. There is one which leaves the top of the rad (this is gotatable from under the bonnet.)
The other leaves the top/front of the engine getatable from under the drivers seat/underneath bongo.
The one under the drivers seat is normally the first to go. (it gets the hottest coolant)also when it gets old and swells it rubs on a couple of sharp bits and wears away. Check this one out if it's the other and change both whilst your about it.....Do you know hoe to bleed the system when youv'e changed it/them ?? If you don't make sure you find out and if a garage is doing it make sure they do. If they haven't done a few bongos there is a good chance they will mess up.
Download the "bleeding" factsheet
- mister munkey
Re: top hose help
Put a location up Shadow, its easier to point you to assistance if we know where you are.
Re: top hose help
If you are still not too sure which coolant hoses you require, then I suggest that you send a PM to Flippa containing photographs of the damaged hoses pasted onto the PM using Photobucket.
Flippa will then be able to tell you which hoses you require and give you an estimate as to the cost.
Re: top hose help
Thankyou, it's the hose at the engine end but they both look like they need changing
Re: top hose help
Hi there.
I would check the metal pipe as well between the hoses whilst it is appart. This can corrode.
F Zappa
F Zappa
