Air escaping
Air escaping
When I park and turn off the engine I can hear air escaping from under the chassis, basically sounds like a tyre deflating - however they are all fine, lasts about 20 to 30 seconds. Any ideas? I'm still under warranty but would like to go back to dealer prearmed with some info.
J
J
Re: Air escaping
Hmmmm - strange one. Leaky aircon system? No idea really. Hope others may be along to help soon
- Eat Aunt
- Location: Bongoing since 2005 in the Portsmouth area :)
Re: Air escaping
Sounds like your may may have a slight leak in one of your hoses, have you checked your expansion tank coolant level ?Puggy wrote:Hi
J
The same hissing sound was the first clue when I first had a water leak in one of my Bongo's hoses.
Have a look under your passenger seat and drivers seat when you first hear it again.
Just a thought, maybe wrong
20 YEARS BONGO-ING
Black Std 2WD AFT
Now 2001 WHITE V6 Tintop ... 253,000 Km
Black Std 2WD AFT
Re: Air escaping
Well I wondered about that (perhaps should have said) but then thought wouldn't they have had another sign, like an engine boiling over due to lack of coolant, or a pool of liquid underneath the Bongo? But now that you've posted this as a possibility, I'd have to say it must go to the top of the list as it needs to fixed before you lose coolant and potentially wreck the engine. So, Good callEat Aunt wrote:Sounds like your may may have a slight leak in one of your hoses, have you checked your expansion tank coolant level ?Puggy wrote:Hi
J
- Eat Aunt
Re: Air escaping
Yea mikeonb4c,
not long after I got my workhorse, oops I mean Bongo in summer 05 I noticed a hissing noise coming from underneath after turning engine off and thought, where the f**k is that hissing coming from. Needless to say lifting the drivers seat the culprit hose was found. Having driven fire engines for many years, strange hissing noises coming from the vehicle (not the crew
) and the various systems were not uncommon lol
20 YEARS BONGO-ING
Black Std 2WD AFT
Black Std 2WD AFT
Re: Air escaping
Another thought is that there may be a problem with the vacuum pump system. This is located near the power steering pump on the drivers side. There is a pipe that runs up the front of the engine by the cambelt cover & another one that goes off to the brake servo under the bonnet. Maybe there is a leak in there which is sucking air in & the noise you can here is the pressure equalising. If you left both seats & can identify which side of the engine the noise is coming from, then you'll have a better idea where the problem is.
A final (less likely) suggestion is that the van is fitted with air-assisted suspension. There are at least 2 owners I know of who have this fitted, so it's not impossible that yours has it too.
Good luck.
Good luck.
Re: Air escaping
It was a fractured hose, in garage getting fixed but not ready until Monday due to getting parts from Mazda...grrr, thanks for the spot on advice
J
J
- Eat Aunt
Re: Air escaping
Phew
Well done for catching it in time
20 YEARS BONGO-ING
Black Std 2WD AFT
Black Std 2WD AFT
Re: Air escaping
Good news. Strongly recommend fitting a low coolant alarm as insurance against a recurrence. Not much to pay for peace of mind. Good luck and happy Bongoing. Well done Eat Aunt who ID'd it.
