* Sticking the bung back in the bleed pipe without getting scalded
* Being able to bleed 1 - 2 litres of water from the pipe without letting the level drop in the expansion tank
This is my proposed solution:
1) Fit an on/off valve in the end in the bleed pipe. I have several John Guest push-fit valves & fittings as used in for plastic water pipe (central heating, beer pump lines etc). If this is fitted securely then there is no reason why it can't stay fitted all the time.
2) A length of pipe goes to the bottom of a plastic 'sight glass' which allows you to see the coolant passing thru & more importantly see when the bubbles have settled down.
3) From the top of this is a pipe going to a 5 litre plastic tank which has two pumps in the bottom. This is just a windscreen washer bottle & 12v pumps from a scrapyard. I have choosen a type with 2 pumps to give a decent flow
4) The output from the pumps goes back up to the expansion tank.
5) The pumps are controlled by a simple circuit which interfaces to the low coolant alarm.
So, open the valve & let the coolant start to flow. The bubbles will be visible in the sight glass & because the water goes from bottom to top, it effectively creates a U-bend which will prevent air being sucked back in. When the level in the expansion tank drops, the alarm will come on & the pumps will replenish the coolant. In theory, as long the rate at which the pumps refil the tank at least matches that which the coolant leaves the bleed pipe, then you could leave it running indefinately until all the air is purged.
What do you reckon - constructive comments welcomed (no big arguments please
