Do I have an exhaust problem?
moo n' mad
Post by moo n' mad » Thu Nov 27, 2008 8:43 pm
Our Bongo (SGL5) has developed the following;
Rattles like a bag of nails lots of vibration through the dashand steering wheel
Smell (like bacon frazzles) coming through the vents after using the kickdown and while idling
Fuel consumption right up
Faint windy noise when accelerating
Loss of performance
Handles like a boat :shock:
These symptoms are getting worse. My guess was exhaust. We have taken it to an exhaust fitting place who say that the exhaust (pipes I assume) and whole undercarriage are in very good nick.
In a similar forum query Hayden mentioned exhaust valves......whats them then? Can anyone help? Is it safe to drive? We have a meet this weekend luckily only about 20 miles away. [-o<
Re: Do I have an exhaust problem?
Post by francophile1947 » Thu Nov 27, 2008 9:01 pm
Rattles and bad handling sounds like anti-roll bar bushes and/or droplinks - both easy and cheap to fix.
Loss of performance and increased fuel consumption could be a blocked air filter (when was it last changed?) or fuel starvation (check filters)
Smell - no idea, unless it's overheating.
Noise when accelerating could just be turbo, or the start of the number one exhaust manifold stud sheared.
dandywarhol
Post by dandywarhol » Thu Nov 27, 2008 9:04 pm
It won't address the handling problem but check you haven't got a rag or plastic bag sucked up the air intake to the left (looking at it) of the radiator
Post by missfixit70 » Thu Nov 27, 2008 9:04 pm
Binding brakes? You haven't got a pig wedged underneath have you, might explaing the frazzles :?
You guys coming to Chew Valley then?
haydn callow
Post by haydn callow » Thu Nov 27, 2008 9:52 pm
I say "exaust valves" ??
In relation to what/when ??
http://www.coolantalarm.co.uk
Also BMW Clocks
Post by francophile1947 » Thu Nov 27, 2008 9:56 pm
haydn callow wrote:I say "exaust valves" ??
I'm guessing he's referring to the valve in the exhaust, with the Winter pack - don't remember anybody mentioning the valves in the engine :?
haydn callow
Post by haydn callow » Thu Nov 27, 2008 11:09 pm
Ah !! now that's a possibility. Worth checking out.
Also BMW Clocks
mister munkey
Post by mister munkey » Thu Nov 27, 2008 11:19 pm
If that is the case - & it well maybe - & if you have the twin battery set up, check the cold start switch by your right knee isn't on. That alone could cause most of that nastiness.
Good luck, hope its simple.
[-o<
carlioll
Post by carlioll » Thu Nov 27, 2008 11:54 pm
Regarding your vibrations and handling problems -I would start with a good inspection of the tyres looking especially for any blebs or bulging on the tread of the tyres especially the front tyres . I once had a tyre with a bulge on the tread - and the vibration caused by that was shocking.
dandywarhol
Post by dandywarhol » Fri Nov 28, 2008 12:45 am
Ahhhh forgotten that one - good shout - that'll cover all the symptoms - especially a high mileage 4WD
moo n' mad
Post by moo n' mad » Fri Nov 28, 2008 12:25 pm
Thanks to everyone for the tips and advice. =D>
We have recently had new tyres on the front and a service in September so I might start with the plastic bag and exhaust valve (it is a winter model) I will go check that switch too.
I will pop out shortly and take a closer look, paying especial attention to any trapped pigs. I don't care what anyone says that's just what it smells like.
Yes we are coming tomorrow, I will be off to make some minestrone soup and fresh rolls shortly. Forecast at the moment fog then sun. PS if I find a pig Missfixit do you want me to save you some :lol:
Post by missfixit70 » Fri Nov 28, 2008 1:06 pm
Hog roast at Chew Valley, sounds good :lol:
BONGO-LOUIS
Post by BONGO-LOUIS » Sat Nov 29, 2008 12:32 am
missfixit70 wrote:Hog roast at Chew Valley, sounds good :lol:
we will bring the apple sauce :lol: :lol: :lol: :lol: :lol: :lol:
