cheffy34
Post
by cheffy34 » Tue Nov 18, 2008 10:04 am
hogggman wrote:hi,
now i don`t know if the light was due to the lambda sensor or the wire that goes to the cat,as i cleaned the lambda sensor connections and it hasn`t come back on today.the wire to the cat had been dangling down touching,but not connected to,the cat,so maybe it was making a connection/short or something?that is now tidied up out of the way.
thanks
jamie
If it's not connected Jamie the light doesn't come on
manners
Post
by manners » Wed Nov 19, 2008 6:58 pm
No heat light anywhere on mine ABS light above the roof light? Is it a winter pack option?
cheffy34
Post
by cheffy34 » Wed Nov 19, 2008 7:44 pm
Dunno, but can you do me favour manners
have alook at your cat pipe for me and see if you have a sensor sticking out the side of it, what year is yours
my light is bottom right hand side of the dash below the abs light only used
to come on when you first started the motor
then go out
manners
Post
by manners » Wed Nov 19, 2008 7:53 pm
There's a sensor comming out of the top of the cat two wire one blue and one white does this help? mine's a new shape Sep'99
cheffy34
Post
by cheffy34 » Wed Nov 19, 2008 8:00 pm
manners wrote:There's a sensor comming out of the top of the cat two wire one blue and one white does this help? mine's a new shape Sep'99
Long and thin wire type sensor with an elbow bend in it
or short fat and stumpy, reckon yours could be different to mine:roll: it is newer than mine suppose tho
manners
Post
by manners » Wed Nov 19, 2008 9:07 pm
No elbow its about 3/8" wide and 2" long or 10mm x 50mm
mrs hogggman
Post
by mrs hogggman » Wed Nov 19, 2008 9:10 pm
sorry manners,are you sure you`re looking at the cat and not the bit before?
cheffy34
Post
by cheffy34 » Wed Nov 19, 2008 10:26 pm
manners wrote:No elbow its about 3/8" wide and 2" long or 10mm x 50mm
could be the lambda
that is pre cat the thermo is in the middle of the cat can, Another member tells me his hasn't got it either on his v6
manners
Post
by manners » Wed Nov 19, 2008 11:51 pm
mrs hogggman wrote:sorry manners,are you sure you`re looking at the cat and not the bit before?
Bang on center of the cat not the pipe.
cheffy34
Post
by cheffy34 » Thu Nov 20, 2008 9:38 am
manners wrote:mrs hogggman wrote:sorry manners,are you sure you`re looking at the cat and not the bit before?
the same but different, i tried to look on lush projects but the damn pass code has changed again
manners
Post
by manners » Thu Nov 20, 2008 6:15 pm
Just had a look on lush projects does not show any sensors lambda or otherwise.
apole
Post
by apole » Fri Nov 21, 2008 10:27 am
It depends on which model year you look at and at what section, I couldn't find mine for ages. It looks like the new shape bongos only have a lambda, whereas the others have both.
New Forest Terrier
Post
by New Forest Terrier » Fri Nov 21, 2008 8:37 pm
My 95 V6 has the two sensors. Lambda before the cat and the heat sensor in the middle of the cat. No elbow both go straight down with no wires visable as they are both completely sleeved.
The single sensor on the later Bongo is probably a combined heat and Lambda. Both feed back into the ECU. Lambda for the O2 measurement and heat to monitor the working temperature of the cat.
My heat light is second row up and the side nearest the steering wheel. Comes on on start up and then goes out straight away. Possibly a check that the sensors are inputing to the EMS? The Volvo one does that.
If the heat sensor is not inputing it would lead to higher fuel consumption as the ECU will not register the catalyst has reached working temperature.
The BewilderBeast - V6 Mean Green Tintop with LPG and 321 Away Montague Conversion
cheffy34
Post
by cheffy34 » Sat Nov 22, 2008 4:01 am
dandywarhol
Post
by dandywarhol » Sat Nov 22, 2008 11:30 am
A 4 wire lamda sensor is just a 2 wire one with additional feed and earth to heat up the sensor element to allow it to operate earlier.
