Headlamp beams seem too high
Despite the MOT pre-delivery of our new Bongo, its headlamp beams (dipped and full) look too high, compared with our other car, and compared with other vehicles on the road this evening. So, I'm not surprised that I'm getting a few indignant headlamp flashes.
Are the two big knurled nuts, on the back of our (new shape Bongo) headlamp housings, beam adjusters or simply cover removal nuts for bulb replacement? Haven't had time to try them since getting back in, so thought I might as well ask before possibly screwing up (pun not intended) the beams tomorrow. Is there a standard pattern one should work to in adjusting beams?
Thanks.
Thanks.
- westonwarrior
Re: Headlamp beams seem too high
Fit big spots and wire them up to main beam and when you get flashed you can blast them with full on blinders
Glad you're not in this part of the country, Westonwarrior!
MountainGoat has very kindly PM'd the relevant service manual page to me, so I'm OK now everybody. Thanks again M/G, and once again, thanks to a great forum.
- westonwarrior
As if I would really
Lower the van
Tee hee. Have to put my hands up and say if someone persists in driving at me whilst on main beam at night, damaging my night vision, I'm likely to give them just the briefest blip of main beam + spotlights. Just to get their attention you understandwestonwarrior wrote:Fit big spots and wire them up to main beam and when you get flashed you can blast them with full on blinders
Surely, raise the back - sort of dragster Bongocheffy34 wrote:Lower the van
Better not now - we'll all know it's you (or Mike)westonwarrior wrote:As if I would really
Ron Miel wrote:Surely, raise the back - sort of dragster Bongocheffy34 wrote:Lower the van
And why not
- You've Been Bongod
now now rob thats naughty
have you been to the same school of motoring as me
- dandywarhol
Drive against a garage door, full beam, mark the centre spot with chalk on the door, drive back 25 ft (assuming a level ground) and adjust the lamps to the chalk mark - you'll find it's pretty close for the MOT testers
- missfixit70
Wonder if the MOT was done before the conversion?, Imperials vans are stripped before they get their mitts on them to convert, if it was MOTed when it was stripped - before the conversion?
Can you get it MOT'd without it being registered? As a 7 yr old Bongo can't be registered without a conversion, maybe that answers Missfixit's question?
