Small lever under bonnet.
http://i365.photobucket.com/albums/oo93 ... C00745.jpg
http://i365.photobucket.com/albums/oo93 ... C00744.jpg
can anyone tell me what this lever is for and what position it should be in?
- daveblueozzie
Re: Small lever under bonnet.
Not 100% sure ,but i think its a summer/winter lever for the amount of air into the system,
so open for summer, partially closed for winter.
Lost without my Bongo.
what difference would the air make Dave in winter or summer? intersting ..
would it affect the cooling or just the heating for the inside?
- crazy uncle gray g
Cabte, If the lever is for the purpose Dave thinks,
I guess it works for the same reason these do
http://www.alaskatent.com/products/cove ... fronts.htm
cheers! party on dudes.
Ahhh! Takes me back to the days of my old Brit cars, that liked to have a blanket on the rad grille or else silver foil partially covering the rad in cold weather.crazy uncle gray g wrote:Cabte, If the lever is for the purpose Dave thinks,
I guess it works for the same reason these do![]()
I wonder if this Bongo is a cold weather (N Japan) vaariety, with the twin starter batteries etc.?
Either way, must check mine when I get home
From the manual that lever is summer/winter but for the air intake into the heating system, not the engine air in-take.
I think that when it's forward (i.e. to the front of the car that is summer, and pushed back towards the windscreen is winter).
- haydn callow
That lever is controlled by one of the sliders on your heating/air con controls. The models that have the electronic auto climate control do not have it fitted.
It controls the amount of air that the fan can draw by deflecting excess air away
Aah! You clever old sausagehaydn callow wrote:That lever is controlled by one of the sliders on your heating/air con controls. The models that have the electronic auto climate control do not have it fitted.
- dandywarhol
Well, thats a load of tosh Haydnhaydn callow wrote:That lever is controlled by one of the sliders on your heating/air con controls. The models that have the electronic auto climate control do not have it fitted.
http://www.lushprojects.com/bongoparts/ ... R12921.gif
- haydn callow
I'm ever so sorry...Had a Bongo round a couple of weeks ago and we spotted that lever (mine is the climate version so just has the spindle and no lever. Between us we made it work by moving one of the sliders on the control (don't know which one as I had my head under the bonnet) we watched the "flap inside the trunking move and both agreed that what I posted was what was happening.
Again sorry for the Tosh.
My Bongo is from the north.
Oooh, so now I'm a clever old sausage. Not often I get to be thatdandywarhol wrote:Well, thats a load of tosh Haydnhaydn callow wrote:That lever is controlled by one of the sliders on your heating/air con controls. The models that have the electronic auto climate control do not have it fitted.
It controls the amount of air that the fan can draw by deflecting excess air away- it's a manual control for some Northern Japan Bongos to direct warmer air into the interior heating system.
- maxheadroom
Don't know but me I would just pull it and see what happensemma & ian wrote:http://i365.photobucket.com/albums/oo93 ... C00745.jpg
- dandywarhol
It's only manual on the ones I've worked on Haydn - nothing attached to it as the pic shows - it's a manual winter/summer lever to direct the incoming air.
Hope your Bongo isn't from the North West - people will be laughing........
