Help needed with windscreen wipers hitting the drivers side door pillar.
I am no DIY mechanic and I had my bongo friendly mechanic look at the wipers. They have just started to hit the door pillar with a very large thump. My mechanic tried to re-position the wipers but the amount of slack in the wipers (approx 6 inches of movement) his conclusion was that the wiper linkage mechanism would need replacing or a bushing kit would need to be found.
So the question is does anyone know where I can find a new wiper linkage or bushing kit.
I've got a 1998 S Reg SGL5 Montague
Windscreen wiper linkage / bushing kit
Beep Beep Beep Beep Beep Beep Beep.............. Ok I give up what have we left on!!!!!!!
Re: Windscreen wiper linkage / bushing kit
Thre was a thread on this recently as someone had 'slapping wipers'. I think the general view was to find a replacement mechanism from a breaking Bongo but have a search on here and see if you can track down the thread. Good luck
- missfixit70
Kirsty - you are amazing!missfixit70 wrote:This one? - http://www.igmaynard.co.uk/bongo/forum/ ... er&start=0
Thanks for that I have seen the thread and I will give it a try.
Is this a common problem with Bongo wipers or am I one of the lucky few?.... just there doesn't seem to be much on the forum.
Thanks once again.
Thanks once again.
Only you and that other thread, not heard of any others. But to borrow the famous line from Top Gun
"You fly Bongos long enough, this kind of thing is bound to happen. But there wil be others - you can count on it. You gotta let him go."
Love the TG Quote, thanks for the info I will count myself lucky!
Solved the problem, or I should say have nearly solved the problem.
Got a wiper linkage (2nd Hand) from Bongobits on the way. Should have clonk free wiping at the weekend.
Enjoy the rain everyone! I know I will!!!
