maybe trouble ahead?????? on start up
andyb36
Post by andyb36 » Mon Nov 03, 2008 11:32 am
well i hope i am not jinxing my bongo in to something wrong, cos i may be over reacting :roll:
ive had the bongo since may and not had a single hintch so far and has ran like a dream
but sometimes on start up after starting, left on tick over it starts to ......hard to describe...
its as if it pinks,,,missing a beat now and then ( it is a diesel, so i know it isnt pinking )
give it a couple of revs and all clear
this doesnt happen all the time, and i dont use everyday,,,,sometimes it will do it the next day
leave for a week and it doesnt do it,,,,,,damp weather sometimes and sometimes not
like i said a couple of slow revs or revs up for 10 seconds and cleared
is this a sign or nothing to be concerned about
after the couple of revs on the occasions it does do it,,,,drives faultless and never missed a beat
i think im prob just being over cautious, but just wondering if any others get the same symptoms
maybe just damp etc etc etc just asking for thoughts
andy
still havnt managed to set up my new kyham motordome classic yet due to other things and weather :evil: :evil: :evil: :evil: :evil:
god i dont like this side of the year
apole
Re: maybe trouble ahead?????? on start up
Post by apole » Mon Nov 03, 2008 12:20 pm
Hi there,
I'm sure someone more knowledgeable will be along soon but in the meantime it could well be that you have a duff glowplug so that not all cylinders are firing initially.
Had an old Golf diesel way back that did this, doesn't sound so good then suddenly clears.
There is a way to test them with a multimeter, try googling test glowplug.
I am presuming yours is diesel and not petrol.
Trouble at t'Mill
Post by Trouble at t'Mill » Mon Nov 03, 2008 12:27 pm
Hi Andy.
Bit hard to diagnose from here, but I would have thought it was unlikely to be anything major, if the car runs well at other times and once warmed up.
In cold weather, the glow plugs become very important - a dash light comes on for a few seconds after you turn on the ignition to show the plugs are being heated. If one plug has failed - something that'll happen every mow and then - then the engine will initially only fire up properly on 3 cylinders, and it will sound pretty rough! After running for a few seconds, it should settle down and the 'missing' cylinder starts to ignite properly too.
A garage will be able to check in minutes whether a glow plug has gone - they seem easy to access in these cars.
Damp doesn't affect diesels like it does petrol engines, since diesels don't require a spark to ignite the cylinders. Therefore, they are pretty immune to wet conditions. It's possible it could affect other control electrics, though - I'm not familiar with how complex the Bongo's management system is.
Meanwhile, something I think is worth trying is a good quality fuel additive such as Millers Power Plus/Sport. As well as generally improving the quality of combustion, they will thoroughly clean out your injectors which can suffer especially if run on cheap 'supermarket' fuel. I use it fairly regularly, adding a double dose when my Zafira started playing up - service light coming on, and car going into 'limp home' mode. A brisk drive with some of that in the tank seems to have cured it (can't be sure it's all down to the additive, of course!)
daveblueozzie
Post by daveblueozzie » Mon Nov 03, 2008 12:49 pm
Like everyone has said probably nothing to worry about, but a bit of a service wont do any harm,
new glow plugs, new fuel filter (fill fuel filter with injector fluid then replace,ready primed then, easier to start)
check and clean the banjo filter.(on top of fuel pump)
new oil and air filter as well.
then your ready for the winter. =D>
Lost without my Bongo.
Post by bigdaddycain » Mon Nov 03, 2008 12:50 pm
I agree with the above, in addition, do you run veg oil in the bongo? Mine stumbles on a stone cold start in this weather with veggy,hence why i'm on 100% neat diesel at this time of year.
I let my glowplug light extinguish, then count to 5, then crank up the old girl in this weather, the light is just an indicator, the plugs are still glowing after the light has gone out. :wink:
Post by bigdaddycain » Mon Nov 03, 2008 12:52 pm
daveblueozzie wrote: then your ready for the winter. =D>
Don't forget to wear two pairs of smelly socks...clean socks don't insulate from the cold quite so well.
andyb36
Post by andyb36 » Mon Nov 03, 2008 1:02 pm
:lol: :lol: :lol: cheers guys
like i said only does it now and then
i always let the plug light go out before i attempt to start
and i must admit, it starts within a second, no spinning over or nothing,,,instant running
its just after the 1st few seconds,,,,and again,, not all the time
yep, check the plugs and a service
only done up to 2000 miles since the last service ??
is it worth the oil change etc yes is my bongo worth it????
of course its worth it,,, but is it nessesary
andy
Post by bigdaddycain » Mon Nov 03, 2008 1:08 pm
2000 miles since your last service? you should be good for another 3k yet.
Mine does stumble even with 100% diesel every once in a while, but only when i have been impatient and cranked from cold before the light has gone out.
Post by bigdaddycain » Mon Nov 03, 2008 1:11 pm
Just out of curiosity, what engine oil do you run andy? I found 15/40 a bit...gloopy? My bongo seems to run sweetly when cold on 10/40 semi synth. :wink:
andyb36
Post by andyb36 » Mon Nov 03, 2008 1:20 pm
hi again
it had not long been serviced before i bought it.......
my bro in law is a mechanic ,,, came to stourport with me
before we went he put my bongo through an mot run, and checked all fluids etc
gearbox, axle , oil , coolant etc said all were spot on and clean
only thing he had to do was increase antifreeze mixture slightly
said if it was the actual mot, flying pass
hope he has same opinion when next may comes lol
only does the splutter thing now and then,,,, guess nothing to really be worried about, as it runs fine
yes ive read up on oils
10/40 - 10/30 but fully syn or semi ????
engines only done 93k kms
andy
Post by bigdaddycain » Mon Nov 03, 2008 1:22 pm
I use semi synth, fully synth is a bit too thin in my opinion for the bongo.
teenmal
Post by teenmal » Mon Nov 03, 2008 3:13 pm
bigdaddycain wrote:I use semi synth, fully synth is a bit too thin in my opinion for the bongo.
Hi BDC,what brand do you use.
Mal..
bongomaan
Post by bongomaan » Mon Nov 03, 2008 7:26 pm
hi andy,your not running with Japanese coolant are you not everyone changes it on import..
Post by bigdaddycain » Mon Nov 03, 2008 7:39 pm
Mal..
valvoline is my usual choice, but i'm not that fussy as long as it's a recognised brand. Granville make a decent oil too, i'm quite impressed by their engine oil.
dandywarhol
Post by dandywarhol » Mon Nov 03, 2008 7:45 pm
Mal..
valvoline is my usual choice, but i'm not that fussy as long as it's a recognised brand. Granville make a decent oil too, i'm quite impressed by their engine oil.[/quote]
If ol' Arkwright had known that he'd have made a fortune out of the little fella........... :lol:
