Help. Are these the Glow Plugs I should be buying?
B*Witched Blingo
Post by B*Witched Blingo » Fri Oct 31, 2008 7:21 pm
I have noticed the last couple of times I have started Blingo she has been a bit chuggy for about a minute or so. I never move off straight away anyway, but I just wondered if this was normal for this time of year. I don't use Veg oil just straight diesel.
I suspect the Glow Plugs may need changing and having looked through all Blingos service records and receipts I find no record of these ever being replaced since import in 2006.
So I have had a tootal around on Ebay and found these.
http://cgi.ebay.co.uk/MAZDA-BONGO-2500c ... 240%3A1318
Has anyone else installed them?. Are they a fair price or am I looking at the wrong thing. Buy the way she is a 96 early 96 on a P if that helps.
If you can help it would be much appreciate it..Please, please. [-o<
You Tube Films Click Here
rwill19050
Re: Help. Are these the Glow Plugs I should be buying?
Post by rwill19050 » Fri Oct 31, 2008 8:15 pm
Just replaced ours.
Got them from Spark Plugs Ltd. sparkplugs.co.uk
Code NGK Y-701J £7-30p each
Cost £40-13 for the set of 4, delivered by Special Delivery (24 Hour)
Cheaper delivery available.
Richard
dandywarhol
Post by dandywarhol » Fri Oct 31, 2008 10:06 pm
I agree with Richard - I've seen cheapo chinese copies fall apart in the engine - best to stick with NGK
daveblueozzie
Post by daveblueozzie » Fri Oct 31, 2008 11:04 pm
there are two sizes of heater plugs, make sure you get the right ones for your vehicle.
dont quote me on this ,but Wheelquick will fit and supply for around £60. (well that was the price for me anyway)
Lost without my Bongo.
kawasaki kid
Post by kawasaki kid » Sat Nov 01, 2008 12:25 am
I fitted those glowplugs and up to now they have been spot on - did fit cheaper ones and had to replace them 12 months later. :oops:
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
B*Witched Blingo
Post by B*Witched Blingo » Sat Nov 01, 2008 12:54 am
thankyou for your suggests. I will make that call. Much appreciated.
