Stainless Steel Exhausts - any recommendations please
Re: Stainless Steel Exhausts - any recommendations please
Post by mikeonb4c » Tue Oct 21, 2008 10:00 pm
I'd be careful Simon. Its a fair bit of pressure coming out the Bongo exhaust and - as you say - it may well shoot straight up into the Eberspacher and crud it up or worse over time. Plus once you've drilled the s/s exhaust (fun drilling s/s/ too I believe) you can't undrill it. Can't the Eberspacher just be given it's own extension either taking it over to the offside or else clipped to the exhaust for support while it heads the same way?
the janner vanner
Post by the janner vanner » Wed Oct 22, 2008 7:12 am
Brill Simon, lets hope you get it sorted before the Looe bash at New Year.
The Janner Vanner
Post by bigdaddycain » Wed Oct 22, 2008 10:02 am
mikeonb4c wrote:I'd be careful Simon. Its a fair bit of pressure coming out the Bongo exhaust and - as you say - it may well shoot straight up into the Eberspacher and crud it up or worse over time. Plus once you've drilled the s/s exhaust (fun drilling s/s/ too I believe) you can't undrill it. Can't the Eberspacher just be given it's own extension either taking it over to the offside or else clipped to the exhaust for support while it heads the same way?
I was just trying to come up with a neat installation idea mike,of course the exhaust wouldn't need to be drilled should the eberspacher exhaust simply follow the bongo's exhaust route, (with ties as you suggest), but it would have been neat to have it exhausting via the bongo's exhaust. the eberspacher exhaust could simply be strapped underneath,and the end of the pipe stop a few inches short of the regular exhaust.
Post by missfixit70 » Wed Oct 22, 2008 1:11 pm
Matching exhaust tip & some tubing routed on the other side- possibly utilising the old exhaust in some way - you then got twin exhausts & the exhaust is then even further away from the awning side of the van. Just an idea :wink:
Simon Jones
Post by Simon Jones » Wed Oct 22, 2008 1:38 pm
Thanks for the suggestions. The reason for the mod was to avoid spending a fortune on buying 3 metres of 24mm s/s exhaust pipe for the heater. Having looked again, it can be bought for about £12.50 / metre, so messing around drilling & welding the exhaust is probably not worth the hassle. It will be just as easy to run it along a similar route to the rear of the van. Nice idea Kirsty about having a second tailpipe in the other side - I'll see what I can find.
The plan would have been to weld the adjoining pipe at an angle to create a venturii effect, such that it would tend to suck air into the main exhaust, rather than blow it out into the heater.
Anyway, I think I've talked myself out of that idea (with your help!) :)
Post by mikeonb4c » Wed Oct 22, 2008 3:10 pm
Simon Jones wrote:The plan would have been to weld the adjoining pipe at an angle to create a venturii effect, such that it would tend to suck air into the main exhaust, rather than blow it out into the heater.
You'd think that would work, as long as the Eberspacher is happy to have air drawn through it. I suppose that if you're confident about your s/s welding skills and have a scrap that you can weld back over the hole if the experiement fails, then maybe it's worth a try. Nothing ventured etc.
So that's me doing a complete U-turn on the subject :lol: :lol: :lol:
Simon Jones
Post by Simon Jones » Wed Oct 22, 2008 7:27 pm
Nah - like I say, not worth the risk of screwing up a new exhaust & the heater for the sake of trying to save about £40. Thanks again for all the suggestions on the subject.
Post by bigdaddycain » Thu Oct 23, 2008 1:42 pm
Or...Nothing "venturii'd" eh mike? ... (already got me coat on...i won't bother getting it) :lol:
Post by mikeonb4c » Thu Oct 23, 2008 2:18 pm
Booom Booooom =D>
8)
