duncsuk
Post
by duncsuk » Sat Oct 04, 2008 1:37 pm
Having got fed up with the reversing beep, I've followed the forum instructions and disconnected the unit in the drivers footwell (RHS) .. peace
To do this, I unplugged the complete connector.
However, I now realise that this unit must also control the 'lights-left-on' beep, as that (rather useful) beep has also disappeared. Is is possible to configure the plug so that the lights-on beep works, but the reversing beep does not? If so, how ?
TIA ...
Duncan
sparkymik
Post
by sparkymik » Sat Oct 04, 2008 1:46 pm
Good question I've often wondered about that myself, as I have left the lights on I do have new batt's fitted but on day you know it's gonna happen
Sparky
The Bongo has gone. Long live The Bongo
Hymer Camp Swing 544/Fiat Ducato 2.3jtd
brorabongo
Post
by brorabongo » Sat Oct 04, 2008 2:01 pm
The reversing beep is only on the automatics, which I don't have. I guessing then, that there must be a sensor/switch which is activated when you select reverse, so disconnecting it would hopefully do the job.
ボンゴの激怒 pictures
Run your fingers over my Bongo, and I'll run my Bongo over your fingers!!
westonwarrior
Post
by westonwarrior » Sat Oct 04, 2008 2:31 pm
Under the cover of the streeing column is a white connector unconnect that and the reversing light beep and keys in ignition with door open stops but the light on beep with door open works.
Except if you have the lights on the reversing beeps starts again
duncsuk
Post
by duncsuk » Sun Oct 05, 2008 1:21 pm
Thanks for the suggestions
I've just checked and the white connector you mention is already unplugged by a previous owner ?? As I recall, he said that unplugging this solved the annoyance of 'keys-in-ignition' beep .. but didn't affect the reversing beep.
Think I'll have look for the sensor that brorabongo suggests next ...
Thanks ..
westonwarrior
Post
by westonwarrior » Sun Oct 05, 2008 5:23 pm
Strange as I just went and checked in case I made a mistake
mine works exactly as I described.
do your side lights come on with the ignition?
duncsuk
Post
by duncsuk » Sun Oct 05, 2008 6:35 pm
No - they come on without the key in.
Got me thinking ... just dis-connected the leisure battery, but that made no difference (ie. lights still on). Couldn't find the reversing switch ... but that probably operates the reversing lamp, so probably couldn't disconnect anyway. Is the 'beeper' itself the same for all warnings or one for each ?
Post
by mikeonb4c » Sun Oct 05, 2008 8:47 pm
duncsuk wrote:Thanks for the suggestions
Thanks ..
Can you guys help me. I'd like to reach this little white connector and unplug the wotsit that makes the keys in ignition buzzer go off. But I can't see how to get at short of splitting the top and bottom halves of the cowling and they really don't seem to want to split (once screws undone of course assuming I've missed none) and I don't want to do damage. Anyone had this experience / able to advise?
westonwarrior
Post
by westonwarrior » Sun Oct 05, 2008 8:53 pm
I undid all the screws and it didn't want to come apart so I jiggled my hands in the gap and undid the connector.
duncsuk
Post
by duncsuk » Sun Oct 05, 2008 9:03 pm
My connector is released by using a small screwdriver to 'unlock' the tab which 'locks' the plug in place, by pressing down o the tab. This tab is on 'top' of the plug and needs to be gently pushed downwards and then the connector should pull out in the direction of the engine ... at least mine did.
daveblueozzie
Post
by daveblueozzie » Sun Oct 05, 2008 11:08 pm
when i first came onto the forum i too asked about the door key in beep , i was told just to cut the white wire from the green connecting block, so i did ,and it stopped the beep for the ignition key in, dunno if that works for all the bongoes ,but it did for mine,
Lost without my Bongo.
brorabongo
Post
by brorabongo » Sun Oct 05, 2008 11:14 pm
ボンゴの激怒 pictures
bongo bri
Post
by bongo bri » Mon Oct 06, 2008 9:11 pm
[quote="duncsuk"]Hi,
Hi The reverse bleep wire in the footwell connector is red & white.
I have cut mine and insulated the one end and extended the (live) other end to a dashboard light through earth.
Hope this helps
Brian
duncsuk
Post
by duncsuk » Sat Oct 11, 2008 4:49 pm
Hope this helps
Hmmm ...
Yes - it helped. I decided to replace the plug and then cut the said red/white wire. One beep indeed stopped .. the 'lights-on' beep
. Decided then to take the voltmeter (should have done this first, I guess !) and check which wire went 'live' when in reverse ... on my car it's the red/YELLOW wire ... so now all sorted. Reconnected the red/white, cut the red/yellow and all is 'beeping' well
teenmal
Post
by teenmal » Sat Oct 11, 2008 6:10 pm
The first time you reverse into someone or something,by mistake(selected wrong gear)
OOps wish I had a beep to remind me.
Only a thought.
Mal..
