schmokiiiing!!!
alectroll
schmokiiiing!!!
Post by alectroll » Tue Sep 23, 2008 4:50 pm
Hi all, my beloved van has developed a nasty tendancy to belch black smoke out of the back under acceleration. I've tried all the stop-smoke addatives for both the engine and fuel but it onlt cures it for a short time then comes back slowly but surely, and advice would be gratefully accepted!!
Many thanks.
Re: schmokiiiing!!!
Post by francophile1947 » Tue Sep 23, 2008 5:19 pm
Have you blanked off your EGR? - this often helps.
alectroll
Re: schmokiiiing!!!
Post by alectroll » Tue Sep 23, 2008 5:35 pm
sorry for being a biff- EGR?
maxheadroom
Re: schmokiiiing!!!
Post by maxheadroom » Tue Sep 23, 2008 5:39 pm
alectroll wrote:sorry for being a biff- EGR?
Search and you will be rewarded :D
Keep the Faith
Re: schmokiiiing!!!
Post by bigdaddycain » Tue Sep 23, 2008 6:26 pm
Exhaust Gas Recirculation valve.
These can become particularly troublesome on bongo's as they age.
Without going into the in's and out's of exactly how they work, i'll touch on why they are there in the first place.
Japan had/have some serious issues with regards to smog in the more heavily populated areas (tokyo especially) So the government needed to be see n to be doing something about the issue. Hence the E.G.R. fitted to the bongo.
It helps with emissions on tickover,fine when new, but a real pain when they get stuck open or closed.
They aren't really required in the uk market, (i bet 1995 ford rangers don't have one fitted),remove it, blank it off,and enjoy a cleaner running,more fuel efficient,smoother,quieter,more responsive bongo! :wink:
You can source a blanking kit from either allans vehicle services (pm doone), or from forum member nick skidmore. (again, pm him for details).
alectroll
Re: schmokiiiing!!!
Post by alectroll » Tue Sep 23, 2008 6:59 pm
will do, many thanks for the swift advice. incidentally, how many miles do you get out a tank of diesel?
Re: schmokiiiing!!!
Post by bigdaddycain » Tue Sep 23, 2008 7:03 pm
alectroll wrote:will do, many thanks for the swift advice. incidentally, how many miles do you get out a tank of diesel?
I don't have a lot going for me on that front!
360 miles (not km's)to the tank (average).
4WD,bullbars,big wheels,big fat driver...not an ideal recipe for economical driving! I'm quite light footed though when i wanna be. :wink:
alectroll
Re: schmokiiiing!!!
Post by alectroll » Tue Sep 23, 2008 7:11 pm
lol, i wouldn't complain if i got that much!!! mine's currently making about 330ish to a tank! my local garage owner is off on holiday soon with my money!!!
Re: schmokiiiing!!!
Post by bigdaddycain » Tue Sep 23, 2008 7:16 pm
Blanking of the EGR should help a touch... I have a K&N filter instead of the paper elements, and what can only be described as some sort of aftermarket air regulation/monitoring device fitted to my bongo. My bongo doesn't seem to drive much different to any other bongo i have ever driven, so i can't really comment on any dynamic differences from the alterations made to mine.
alectroll
Re: schmokiiiing!!!
Post by alectroll » Tue Sep 23, 2008 7:24 pm
ta, will be heading down the local dealer and get one of those filters tomorrow!! any other tips to increase the mpg?
you may guess by my question i'm not altogether au fait with mechanical stuff!! :cry: :oops:
Re: schmokiiiing!!!
Post by bigdaddycain » Tue Sep 23, 2008 7:29 pm
alectroll wrote: any other tips to increase the mpg?
I'm certainly no authority in such matters alec, but the fundamentals revolve around anticipation of traffic movements ahead, correct inflation of tyres,and if you find you need to use the brakes, you haven't anticipated well enough in the first place! :lol: :lol: :lol:
Loads of tips and hints can be forund on the bongo "fuel & performance" section... :wink:
oggy
Re: schmokiiiing!!!
Post by oggy » Tue Sep 23, 2008 8:22 pm
Hi Alec have had the same problem myself, i have also tried all the additives, got blanking plates from Allans but still the same prob. So today fitted new injectors and they have made a hell of a difference. :D
Cheers Oggy
mister munkey
Re: schmokiiiing!!!
Post by mister munkey » Tue Sep 23, 2008 8:44 pm
Mines blanked off too but still pumps a bit of smoke out when booting it up hill.
I stick a tub of Wynnes Stop Smoke in with each oil change now which helps a bit but doesn't really cure it.
I think the black stuff is unburnt fuel, will check if injectors are healthy at the next spanner session.
bigdaddycain wrote: I don't have a lot going for me on that front!
I rarely see more than 250 on regular running to work/weekends away & stuff. :?
After 200 miles the guage is on E, I risk another 30 or so miles then stuff about 55/60 liters in.
alectroll
Re: schmokiiiing!!!
Post by alectroll » Tue Sep 23, 2008 9:22 pm
ta, when i first got the van i was only getting 280 from a tank and i was seriously disturbed. i tried injector cleaner fluids etc and it seemd to improve a bit but only by about 30 miles or so, then wynnes stop-smoke and also oil treatment. will look into getting the injectors changed and see how that goes.
how easy was it to change them?
dandywarhol
Re: schmokiiiing!!!
Post by dandywarhol » Tue Sep 23, 2008 9:27 pm
Pretty easy if you've the correct deep socket - impossible if you haven't - you'll also need new washers between the injector and the head
