Changing Anti-Roll bar bushes and drop Links
Lloydy
Post by Lloydy » Sat Aug 23, 2008 9:28 pm
Hi all,
My Bongo (ELMO) was clunking from the front from day one and so required attention.
I am no mechanic but relatively hands on. I diagnosed the clunks to be coming from the front anti roll bar bushes AND the drop links. The bushes were very loose and the rubbers on the drop links perished. One of the drop links was also bent??!!
Well anyway... thought i would post these observations for anyone doing the same job:
1) There is a bloke that sells heavy duty drop links on ebay... They cost £38.50 (for the pair) delivered and appear very good quality. They came with everything needed to fit and seem to work a treat.
2) Undoing the old drop links was a bitch. You will need a 17mm spanner to stop the inner bolt turning as you loosen the main bolt. If yours refuses to completly undo like mine did you can secure the drop link to expose the bolt section and cut it off wsith an angle grinder... This was easy and took seconds! Depending on you ratchet depth you may need to invest in a deep set.
3) The bolts for the bush brackets are quite thin and break easily. I used LOADS of eas-it and other tricks and nothing worked! The result was one of the bolts sheering. Something worth knowing is that the bolts cannot be replaced. They are 'studs' that are part of the sub-frame and are difficult to repare... Especially the top ones!
4) Note that the nuts for the bush brackets are 10mm fine threaded. I would suggest finding a couple of spares before you start this job as normal nuts wont fit!!
5) The bushes are very easy to replace by hand. I sprayed them with some TT oil to help the process and this worked a treat. Also good if you need to move the rubber collars for whatever reason!
Hope this helps someone out there. I know its not the techie but it does raise a few points of note for the non-mechanics out there!!
Happy bongoing!
Lloydy. 8)
dreamwarrioruk
Re: Changing Anti-Roll bar bushes and drop Links
Post by dreamwarrioruk » Sat Aug 23, 2008 10:15 pm
its just as easy to grind of the nuts with an angle grinder.
mike, jo and emma
lizard
Post by lizard » Sun Aug 24, 2008 9:29 pm
dreamwarrioruk wrote:its just as easy to grind of the nuts with an angle grinder.
Yes, this would help save another sort of nuts. :lol:
F Zappa
dreamwarrioruk
Post by dreamwarrioruk » Sun Aug 24, 2008 9:42 pm
oh and the vauxhall vecra 95 drop links fit fine for the small sum of £5.70 each. i replaced ours 2 1/2 years ago and they have just started to fail. dont know how long the mazda ones last but someone recently posted they had to change after a year. reckon the vectra one will be worthwhile
mike, jo and emma
Lloydy
Post by Lloydy » Sun Aug 24, 2008 10:46 pm
Great... Now i find this out!!
Oh well... All done and working well now.
brorabongo
Post by brorabongo » Sun Aug 24, 2008 10:57 pm
dreamwarrioruk wrote:oh and the vauxhall vecra 95 drop links fit fine for the small sum of £5.70 each. i replaced ours 2 1/2 years ago and they have just started to fail. dont know how long the mazda ones last but someone recently posted they had to change after a year. reckon the vectra one will be worthwhile
I think the ones that lasted a around a year were cheepies from Ebay, which I have fitted on mine own, 8-[ and not Mazda originals?
ボンゴの激怒 pictures
cheffy34
Post by cheffy34 » Sun Aug 24, 2008 11:22 pm
ditto me to :oops:
