bad vibrations from front when driving
You've Been Bongod
Post by You've Been Bongod » Mon Aug 18, 2008 6:37 pm
hi all as post says bad vibrations from front coming through steering wheel
it aint balacing as had new wheels 2 weeks and were fully balanced by mike at wheelqiuck before fitting them
all i can think it might be is the antiroll link bars which have only been done for 11 months i will check these tommorrow
any ideas would be gratefull [-o<
you've been bongod
Re: bad vibrations from front when driving
Post by missfixit70 » Mon Aug 18, 2008 6:44 pm
It could be that you've lost a weight or two from the wheels being balanced? If you bought the same droplinks as me from ebay, they could be goosed, the rubber on mine only lasted about 10 months, if that, but the seller did replace them without quibble when he saw the photos of them, not sure they'd contribute to the wheel wobble? Any particular speed, or all the time?
Post by francophile1947 » Mon Aug 18, 2008 6:49 pm
Beat me to it Kirsty - a sudden vibration is often a lost balance weight.
You've Been Bongod
Post by You've Been Bongod » Mon Aug 18, 2008 6:52 pm
all the time it only started today and i did buy them off evilbay from ava leisure
you've been bongod
Post by missfixit70 » Mon Aug 18, 2008 7:11 pm
I'd go for another balance check, see if you can see where a weight's fallen off - the stick on ones are especially temperamental, one wrong move with a pressure washer or a blast through a big puddle can take them off.
waycar8
Post by waycar8 » Mon Aug 18, 2008 7:15 pm
i would say the same in regards to the weights, i had the same with my alloys on the focus, one of the stick on weights had fallen off one side and the steering began to shake.
WISHIHADABONGO
Post by WISHIHADABONGO » Mon Aug 18, 2008 7:16 pm
missfixit70 wrote:It could be that you've lost a weight or two from the wheels being balanced? If you bought the same droplinks as me from ebay, they could be goosed, the rubber on mine only lasted about 10 months, if that, but the seller did replace them without quibble when he saw the photos of them, not sure they'd contribute to the wheel wobble? Any particular speed, or all the time?
sorry to "hop on this post" but which droplinks did you buy so we can avoid them?
Magwa
Post by Magwa » Mon Aug 18, 2008 7:16 pm
yeap, been there done that you have lost a weight
Live long die oblong
Post by mikeonb4c » Mon Aug 18, 2008 8:56 pm
....though my personal experience has been that imbalance only really starts to show in the steering once speed is over 60 mph or so. Have I been 'lucky' :roll:
Post by francophile1947 » Mon Aug 18, 2008 9:40 pm
mikeonb4c wrote:....though my personal experience has been that imbalance only really starts to show in the steering once speed is over 60 mph or so. Have I been 'lucky' :roll:
A lost weight, especially a large one, will cause vibration from very low speeds Mike - so I guess you've been lucky not to lose a large weight :lol: :lol: :lol:
Simon Jones
Post by Simon Jones » Mon Aug 18, 2008 9:43 pm
Did you have the wobble before they were balanced & did having them done make it any better or worse? I get a wobble from my steering wheel & it seems to come & go almost as if both wheels have to be at a certain position relative to each other to get the imbalance. It's not so bad that I feel the need to do anything about it - just a minor issue.
teenmal
Post by teenmal » Mon Aug 18, 2008 10:46 pm
Hi YBB,might sound silly but are your WHEEL nuts tight.
Cheers Mal..
You've Been Bongod
Post by You've Been Bongod » Tue Aug 19, 2008 12:52 pm
teenmal wrote:Hi YBB,might sound silly but are your WHEEL nuts tight.
Cheers Mal..
the first things i checked were the nuts :shock:
you've been bongod
Pete & Sue
Post by Pete & Sue » Sun Sep 07, 2008 1:52 pm
Are the spigot rings fitted properly?
Pete & Sue
Turned out nice again!
Post by bigdaddycain » Mon Sep 08, 2008 2:51 am
Did you move the bongo when you last put air in the tyres carl? This is a common bongo trait,with the bongo being a large vehicle,sometimes the airline doesn't quite reach all the way round to the other side, so if you have put air in just the front tyres,move the bongo to reach the rears, then inflate the rears,an imbalance of air (front to rear) can occur.
Have you got a set of those heavy fancy dustcaps fitted carl?
Nah, only joshing...You'll have lost a weight on one of the wheels as the others have stated! :lol: :lol: :lol:
