The temperature gauge always seems to go quite high when not towing (on steep hills it will hover around the top end of scale (excellent Mason alarm fitted) but I found that the gauge was into the red on hills and as I have the set the alarm to the top of scale it was coming on most of the time. The handbrake lever was quite hot at these times and I did put both heaters on to ease the temp. Once up the hills the temperature dropped quite quickly back to normal and the handbrake cooled down quickly too. The Bongo seemed to find it a struggle up the hills - but the weight of the Bongo, plus the trailer and the shed must have been quite significant. The heat from the heaters was positively tropical.
Now the question has to be
Is this what I should Expect when towing a big trailer (the shed was a bit heavy too !! (8' X 5') or should I be looking for possible problems. It is possible that I just have a bad case of Bongonoia (like paranoia only Bongo related)
I have to say that the trailer looked really good on the Bongo - very Junior Eddie Stobart
