wellhouse spot lights
frankie dee
Post by frankie dee » Thu Aug 07, 2008 9:09 pm
my bongo was today in a mazda garage because
my spotlights were not working after 2 hours
there still not working (found both bulbs blown ):cry: .
Now they where fitted by wellhouse in the space in the bumper
also my cibie fog lamps are not working
are they on the same relay??
if so anyone know where the relay is??
this fault is driveing me mad :evil:
Second fault steering rack assembly
its leaking and the mazda garage has said the price of the part
will be in £600/700 range plus fitting :shock: :shock:
any one know of a bongo garage that will fit one/recon for a better price
Regards Frankie
Re: wellhouse spot lights
Post by missfixit70 » Thu Aug 07, 2008 9:37 pm
If the steering rack is leaking from the top the seal can be replaced in situ apparantly, I think Paul9 has done it? The seal kit is available for about £35 I think, not a difficult job apparantly, if you can't do it yourself, any decent garage should be able to. even if you take it off & do all the seals it shouldn't be more than a few hours.
Mine has had a slight leak for a long time, try some of the power steering leak stop stuff first, it may do the trick, has for lots of people.
Try this - http://www.igmaynard.co.uk/bongo/forum/ ... id&start=0
mayk19
Post by mayk19 » Thu Aug 07, 2008 10:18 pm
often your best bet with a bongo is to find a good local garage (one with real auto engineers) buy the parts yourself and get the local garage to fit it. Thats what I do :D I think there is a list available if you become a member of Bongo Fury with a list of good bongo garages.
Hi im Simon
Post by missfixit70 » Thu Aug 07, 2008 11:32 pm
Stick you location in your profile by clicking on "user control panel" top right of the screen, you may get some local help/recommendations :D
