Headgasket
BROTHER00
Headgasket
Post by BROTHER00 » Wed Aug 06, 2008 8:38 pm
new head fitted with new gaskets,blots,waterpump,thermostat.
bleed the cooling system to many times.
but cooling system still throwing water out.
cracked block maybe?
going out of my mind :evil: #-o
bongoing-mad-simon
Re: bloody headgasket
Post by bongoing-mad-simon » Wed Aug 06, 2008 9:56 pm
Hi , I to had this problem and in the end opted for a replacement engine, but others have had success by giving the block a good clean and rub down checking for any unevenness before putting the gaskets back, don't give up you'll get there in the end....make sure the garage you use is fully aware of the bleed procedure for the Bongo .
Simon
I'm Bongoing mad R U?
haydn callow
Re: Headgasket
Post by haydn callow » Wed Aug 06, 2008 10:29 pm
Did you check the top of the engine block was flat before rebuilding and have the head pressure tested??
http://www.coolantalarm.co.uk
Also BMW Clocks
BROTHER00
Re: Headgasket
Post by BROTHER00 » Thu Aug 07, 2008 7:15 am
NEW HEAD FITTED WITH NEW GASKETS.
IF BLOCK IS WARPPED IS THERE ANYTHIBG THAT CAN BE DONE APART FROM REPLACMENT ENGINE.
TALK ABOUT BONGO FURY!!
THANKS FOR YOUR HELP SO FAR.
haydn callow
Re: Headgasket
Post by haydn callow » Thu Aug 07, 2008 8:32 am
You can flatten the block if need be.
It all needs to be done by a GOOD mechnic who knows Bongos.
Also BMW Clocks
Re: Headgasket
Post by francophile1947 » Thu Aug 07, 2008 12:41 pm
There have also been problems with some non-genuine head gaskets.
