Somebody kindly fitted a relay/illume switch and ran the wire to the rear end for me to cut and fit a fog lamp later.
The RAC patrolman on site told me of an alternative method which I had not heard of, Here goes.......
The Bongo rear light clusters have an empty compartment at the bottom of the unit, empty because the fog lamp is not required in Japan, so, here's how to convert this to a functioning fog lamp exactly were it's supposed to be.
No cutting the bumper or danglies!! The job was a peice of cake and took less than an hour.
Obtain an indicator bulb holder (21 w bulb) from a scrap Fiesta or similar. Try to get the plug as well and leave a couple of tails of cable when you cut it off the harness. I didn't have the plug so I used two tiny spade terminals and filled up the gap with hot melt glue.
Use the rubber O ring off the holder to select the correct size hole cutter and also as a template to mark the position
of the hole on the plastic empty compartment wher the lamp is going to go.
Carefully drill the hole, it's about 22mm. It,s possible to just twist the bulb holder into the opening but for gtreater security use a needle file to maks apertures for the little lugs to engage.
Wire up. The live feed from the dash switch and the other to earth. Hey presto....... a perfect fog light in the right place. It really is easy to fit....Honest!!
