If anyone is really concerned about cost but is not concerned about doing to open heart surgery
– You could do what I did
– which was to remove the header tank (actually got a second one from scrappy) and drill a large hole in it and fit a float level switch from RS and wire it into the standard beeper in place of the reversing sensor. This cost about £18 and some strained nerves when I tried it out but has been in place for about a year now and all OK.
One advantage of this is that if you use your Bongo on a regular run – like to work as I do – you can tell what the coolant level is on the move by the alarm going off as you apply inertia to the coolant by taking a right hand at a given speed or by sharp breaking. How long the alarm beeps for is determined by the ‘normal’ steady state level and the time it takes for the coolant to return after being forced away from the float.
So on mine if I get more than 2 – 3 beeps as I pull around the round about out side my house first thing the level is low; if I don’t get at least one beep when breaking very hard then it is unusually high. Normal driving it does not go off at all.
THIS IS STILL NO REPLACE MENT
FOR REGULAR CHECKS UNDER THE BONNET
Just thought I’d throw that into the pot
Regards Grahame
Counting down to Poland
