Tyre pressures.
Tyre pressures.
Is it normal to use the Bongo users manual pressures or do members up the pressures a little, to take account of extra weight either of the conversion or when loaded to go on holiday?
- mister munkey
Re: Tyre pressures.
A question that has been bouncing around for a while . . .
I've very recently changed my wheels. The original 15" alloys seemed happiest at 40 all round but the new 18" felt a bit "skitty" at the front at the same pressure.
I have the fronts at 36, rears at 40 now & all seems well.
I think you just need to play around a little with your own particular set-up & find what feels right.
If it feels right, it probably is.
- brorabongo
Re: Tyre pressures.
I had 40psi in the rears, but had to replace them due to wear in the middle.
Re: Tyre pressures.
Running on the handbook pressures the tyres always look soft, enough that passers by will tell you that you have a soft tyre.
A lot of people on here run higher pressures, maybe try a search for 'Tyre and Pressures'.
Welcome aboard.
Welcome aboard.
