Easy Cooling System Filling
Peg leg Pete
Re: Easy Cooling System Filling
Post by Peg leg Pete » Thu Jul 10, 2008 6:15 pm
The stat has opened and hose hot, just topped up a small amount of coolant the day after coolant change :wink: Mike I am not saying that anybody should go out and spend money on bleeding equipment, I am confident to bleed the system without the pump, but when it was offered free of charge to use, I was curious to give it a try :wink: It worked for me, speeded up the process on a very wet day :wink: Mechanic friend who loaned it says he uses on all types of vehicles that need to be bled. :wink: I agree that it is satisfying to do jobs for yourself, I check the level of coolant on a very regular basis - so too with the hoses etc. :wink:
Image Pete
Post by mikeonb4c » Thu Jul 10, 2008 6:21 pm
Thanks Pete. If I can get my hands on some equipment I'd like to try it when the time comes. Anything for an easy life really 8)
haydn callow
Post by haydn callow » Thu Jul 10, 2008 6:30 pm
I'm convinced...well done...will try my "bike valve" method when next due.
http://www.coolantalarm.co.uk
Also BMW Clocks
Peg leg Pete
Post by Peg leg Pete » Thu Jul 10, 2008 6:32 pm
Look forward to hearing how you get on Haydn :wink:
Image Pete
