Fuel gauge broken....
dr.p
Post by dr.p » Mon Jul 07, 2008 10:10 am
our fuel gauge dropped rapidly from full to empty...took about 10 mins. Then after a while recovered to show correct reading.
Has now died permanently i think.
Anyone know how easy it is to check for possible cause and where to start.
thanks,
dr.p
robdrinky
Re: Fuel gauge broken....
Post by robdrinky » Mon Jul 07, 2008 12:14 pm
you should find lots of info regarding bad earth issues at the sender if you do a search
the voices made me do it!
P reg unconverted blue/grey 2.5td AFT
Post by missfixit70 » Mon Jul 07, 2008 1:04 pm
Could be the dodgy earth from the sender, seems to be a common problem although I've not had it myself, under this plate
apparantly remaking a decent earth sorts it out. It's underneath where the middle seat should be (mines reversed).
dr.p
Post by dr.p » Mon Jul 07, 2008 7:40 pm
thanks for feedback, gauge recovered today so does seem to make sense.... dodgy connection.
unfortunately it's a fully converted van with floor over sender hatch, but i'm pretty sure it can be accessed still.
Rhod
Post by Rhod » Mon Jul 07, 2008 9:44 pm
I had exactly the same symtoms at the weekend. In my case I only had to clean the connector on the sender unit with switch cleaner to restore normal working.
David Edwards
Post by David Edwards » Tue Jul 08, 2008 12:23 am
One tip tho..drill another hole. clean to bare metal and make another second earth as a back up just in case, I did no more trouble since lol. Easy to do. must be cause I did it.
