Front Fog Lights won't work
wooksterdog
Post by wooksterdog » Sun Jul 06, 2008 9:32 pm
Hi and help.
My front fog lights have stopped working. I intended to check the fuse as a first port of call but can't make out which one relates to the front fog lights (if indeed they have a fuse of their own). All the other lights are working fine, including the rear fog light which takes some feed off the front fog light switch.
Has anyone else had this problem, or can anyone offer any guidance as to where I should start.
Rob
aitch
Location: in a place far, far away, well Somerset for now!!!
Re: Front Fog Lights won't work
Post by aitch » Sun Jul 06, 2008 9:36 pm
welcome to the forum
try tracing the wires and check the relay
I did this but mine still do not work
let me know if you trace your fault!!!
Post by missfixit70 » Sun Jul 06, 2008 9:40 pm
If they're factory fit fogs then the fuse is under the bonnet, not sure which one, but it should be a seperate fuse. the fusebox diagrams are in the members area if you've joined the club.
wooksterdog
Post by wooksterdog » Sun Jul 06, 2008 9:42 pm
Thanks, they are factory fit, I will try and trace the fuse under the bonnet.
David Edwards
Post by David Edwards » Sun Jul 06, 2008 10:56 pm
Funny thing but I couldn't get mine to work either but then I remembered.. I didn't have any fitted. :wink: All this info is so valuable tho for when I do fit em should any faults develop.
