power steering rack
paul9
Re: power steering rack
Post by paul9 » Fri Jun 27, 2008 10:36 am
that looks very similar to the kit we had,only needed 1 of the seals pictured,so £28 seemed quite a lot for just one seal,i tried a few different places that made hydrolic seals but couldn't find any,this seal that had gone on all 3 racks is not under any pressure and just seeps a little,so i thought maybe i could find an alternative to buying a full kit and just needing the 1 seal,still checking,will post if i find any.
Post by missfixit70 » Fri Jun 27, 2008 12:47 pm
Nice one Paul, I shall await your findings :D
greg and nyree
Post by greg and nyree » Fri Jun 27, 2008 8:17 pm
[-o<
Mine looks like the top seal at steering columm entry point =D> so maybe will get sorted without taking off :D
greg.
Post by missfixit70 » Fri Jun 27, 2008 8:36 pm
Don't forget photos if you can :D
paul9
Post by paul9 » Sat Jun 28, 2008 5:10 pm
greg and nyree wrote:[-o<
greg.
Have now seen 4 racks leaking from this same place,it is only a small leak ,but can be very annoying and may lead to a mot failer,there is some leak stopper that is added to power steering fluid advertised on ebay and is suppoed to be guaranteed,could be worth a try.
dandywarhol
Post by dandywarhol » Sat Jun 28, 2008 11:21 pm
greg.
Errrm......see post number 10 in this thread.... :roll: :wink:
teenmal
Post by teenmal » Sat Jun 28, 2008 11:40 pm
dandywarhol wrote:I've sorted a few PS leaks with a change of oil with Wynns "Stop Leak"
http://www.wynns.be/product.aspx?nav=1& ... 64559&l=EN
Sceptical at first but it works - different feel to the steering and a quieter pump.
This product is first class,have used it on rear axles,engines,gear boxes etc with great results.(watch out for overdrives may clog very fine filters)..
