furred up negative terminal on leisure battery
hogggman
Post by hogggman » Wed Jun 25, 2008 8:35 pm
hi all,
i`m intermittently losing all leisure battery electrics.i haven`t investigated in depth yet,but have notice a lot of furring/white crud around the negative leisure battery terminal,could this be the cause,or just because of a loose terminal?
thanks
jamie
Simon Jones
Re: furred up negative terminal on leisure battery
Post by Simon Jones » Wed Jun 25, 2008 8:42 pm
Does sound like problem. If it were me, I'd remove both connectors & clean up each clamp & battery terminal with a small wire brush or some fine sandpaper. Then smear both surfaces with petroleum jelly (Vaseline) which will prevent futher oxidation, but without affecting the electrical conductivity. Good luck.
Post by bigdaddycain » Wed Jun 25, 2008 9:19 pm
The sanding of the terminals will increase the conductivity of the connections too, but only temporarily unless the terminals are protected from the damp, as simon suggests....
I use copper grease, this helps to promote a good electrical contact.
cheffy34
Post by cheffy34 » Thu Jun 26, 2008 12:25 am
Yip i use a little copper grease aswell, top tip tho don't leave the tin infront of your van trust me it makes a nasty mess when you forget it and drive over it #-o
Post by bigdaddycain » Thu Jun 26, 2008 12:33 am
Doh! #-o It's not exactly the cheapest grease in the world either cheffy... :shock:
cheffy34
Post by cheffy34 » Thu Jun 26, 2008 12:48 am
bigdaddycain wrote:Doh! #-o It's not exactly the cheapest grease in the world either cheffy... :shock:
Pays to have a mate in the trade :wink: who hates working on jap cars, gives me all his tools n stuff to keep me out of his workshop says go on if you get in trouble gimme a shout i'll come and laugh/help he left it at my house and said it yours said i'd never have to buy it again in my life time it goes for ever #-o reckon i managed to save enuf to see me to retirement :lol: :lol:
Post by bigdaddycain » Thu Jun 26, 2008 12:51 am
That's true, it does go a LONG way! I bought the tin i have about ten years ago, and it'sstill nearly full! I'll lose it before i use it. #-o
