Handbrake Shoes
Benjymac
Handbrake Shoes
Post by Benjymac » Tue Jun 17, 2008 6:12 pm
The brake shoes for my handbrake are worn down to the metal on 2 of the 4 shoes. I enquired about a new set but they cost ~£100 for a full set.
Instead I looked for somewhere that could reline the shoes and found a company called Fleet Factor.
http://www.fleetfactors.co.uk/
I have been quoted £5 a shoe from them so in total it would save me ~£80. In my case two of the shoes still had 3mm of lining left on so I decided to only reline the two shoes that were down to the metal with 3mm lining (the smallest thickness Fleet Factors will do) therefore saving~ £90.
Anyway Fleet Factors have a number of outlets in the North so if you need brake shoes for the handbrake I suggest giving them a try.
I haven't picked them up yet so if there are any issues I will re-post and let you know.
Regards
Benjy
Re: Handbrake Shoes
Post by francophile1947 » Tue Jun 17, 2008 6:31 pm
Interesting!! - why would the shoes be worn - they only work when stationary :? :?
Benjymac
Re: Handbrake Shoes
Post by Benjymac » Tue Jun 17, 2008 8:19 pm
I am guessing either someone before me has been driving around with the handbrake slightly on or they weren't set up properly. Can't really think of any other reason. My guess is that the material on a handbrake shoe could be of a softer quality or less heat resistant because as you say it only has to stop a stationary vehicle from moving.
cheffy34
Re: Handbrake Shoes
Post by cheffy34 » Tue Jun 17, 2008 8:46 pm
francophile1947 wrote:Interesting!! - why would the shoes be worn - they only work when stationary :? :?
I'm always leaving mine on and realising within a few mtrs :roll: [-X
lizard
Re: Handbrake Shoes
Post by lizard » Tue Jun 17, 2008 10:13 pm
Ah ah, boy racers doing hand brake turns :lol:
F Zappa
Re: Handbrake Shoes
Post by mikeonb4c » Tue Jun 17, 2008 10:55 pm
One thing to watch. I have an alarm bell ringing that relining them came up before and there was an issue because the linings are thinner than a normal drum and relining companies couldn't handle that. Could be complete tosh but check with the relining company. Otherwise, if they can do it at a good price, I think you just came up with a contender for top tip of the month 'cos the price for replacements is just silly! =D>
Keep us posted and good luck
Benjymac
Re: Handbrake Shoes
Post by Benjymac » Tue Jun 17, 2008 11:38 pm
Hi Mike,
I did read that on the other thread and that's why I decided to get two relined at 3mm thickness as two of the four still had 3mm of liner on it so there hopefully won't be a problem when refitted. Should be done by the end of the week so will post when refitted.
Benjy
Re: Handbrake Shoes
Post by mikeonb4c » Tue Jun 17, 2008 11:53 pm
Goodo. Sounds like you've covered all the angles. We'll wait to hear
Re: Handbrake Shoes
Post by bigdaddycain » Wed Jun 18, 2008 1:39 am
Hmm, interesting.... I really should check mine, they haven't been touched for at least four or five years that i know of, many a time do i glance down to see the handbrake half on.... :shock: Or is that half off? :-k
Benjymac
Re: Handbrake Shoes
Post by Benjymac » Wed Jun 18, 2008 3:06 am
Half on if your a pessimist and half off if your an optimist :)
Re: Handbrake Shoes
Post by bigdaddycain » Wed Jun 18, 2008 3:08 am
I look at my fuel gauge as half empty benjy...so i guess its half on then mate! :wink:
Benjymac
Re: Handbrake Shoes
Post by Benjymac » Wed Jun 18, 2008 7:29 pm
Well I picked my brake shoes (handbrake) from Fleet Factors this evening. True to his word the cost was £5 per shoe including VAT.
So there you have it £100 for a new set or £20 to get them all relined. As previously stated and having chatted to my mechanic it seems that one shoe on each side is classed as the primary and the other as the secondary. It was my two primaries that had worn (one from each side) so I only needed to reline two shoes at a cost of £10.
Note I relined them at 3mm which was the same thickness as the secondary shoes and it is the minimum thickness they do.
Re: Handbrake Shoes
Post by mikeonb4c » Thu Jun 19, 2008 12:00 am
Excellent piece of work there Benjymac - lets get these guys on the Suppliers List in the Members Area lest nobody finds them again on this thread!!
Benjymac
Re: Handbrake Shoes
Post by Benjymac » Thu Jun 19, 2008 9:52 pm
Hi Mike,
Being lazy, where is the Suppliers List?
Benjy
Re: Handbrake Shoes
Post by mikeonb4c » Thu Jun 19, 2008 10:00 pm
Benjymac wrote:Hi Mike,
Benjy
Its in the Members Area (presume you've joined - worth it if not for all the benefit we get from BF). I'd send a PM to Ian de Bongomeister with the necessary details and he'll delegate someone to update the suppliers list.
