OK, this is why I am posting:
I noticed the other day, I have sprung a leak, before I could identify the pipe, I bought a set of 4 blue silcone ones, but have now discovered the leak in what appears to be a short pipe about 10cm long with a bore of something like 8mm connected to the trurbo unit at one side and top of tehrmostat at other. Just wanted to identify this pipe exactly and check it's size before I order any more parts? Picture are taken form pasenger side inspection cover, front of vehicle to left.
I know I will have to drain system and might as well replace the larger pipes I bought also, plenty of post on that subject here. I have the 'Serivce Manual' also, so should help.
The temp guage is dead (liek that when I bought it) and I have noticed a connector hanging from the underside of the vehicle on dirvers side, i wondered if this might be the connection for temp guage, but might be wishfull thinking, Pictures bellow:
Finally, the vehicle drives fine, but, over rough surface or, potholes ets, I have noticed a knocking/banging sound form the front suspension area, mainly passengeer side but could be both. It's as if some rubber is worn and things are banging when they should be cushioned. I don't know if this is common problem or if it is just normal sound and I am beign paranoid. Sounds a bit loose to me though.
