Creaking drivers door
apole
Post by apole » Fri Jun 06, 2008 4:20 pm
Hi guys,
My drivers door creaks quite badly when going over bumps etc, at least I hope it's my door and not my hip !!
Anyone had this and managed to fix it? All the other doors are fine. Wondering if I grease up the lock mechanism and maybe play around with the adjustment, although it opens and closes fine.
Andy
westonwarrior
Re: Creaking drivers door
Post by westonwarrior » Fri Jun 06, 2008 5:05 pm
Are you certain its the door? when shut it should not move enough to creak,at least i would think not
mine creaks a bit over bumps, I changed the drop links and think it may just be the springs as has been suggested.
apole
Post by apole » Fri Jun 06, 2008 5:28 pm
I'm certain it is the door, you can hear it quite clearly and if you open it a bit the noise stops.
Andy
Post by mikeonb4c » Fri Jun 06, 2008 5:35 pm
Might it be the door card (trim panel) and could you test that theory by removing it and nipping round the block?
oldgit
Post by oldgit » Sat Jun 07, 2008 12:36 pm
When mine creaked it turned out to be the door trim rubbing against the dash trim, sprayed it with dashboard shine, very slippery, and that cured it.Every now and then I have to spray it again.
helen&tony
Post by helen&tony » Sat Jun 07, 2008 1:05 pm
I concur with that ....mine does the same....silicon spray....great invention
apole
Post by apole » Sun Jun 08, 2008 12:08 pm
Glad to report the noise has now gone, I sprayed silicon grease into the door latch mechanism, I'm sure that was it. Anyway the noise is no more which is great.
Thanks for your help.
Andy
Post by bigdaddycain » Sun Jun 08, 2008 3:27 pm
That was a cheap handy tip oldgit and H&T...I'll try to remember that one! :wink: Glad it's sorted apole, it must have been driving you mad!
apole
Post by apole » Sun Jun 08, 2008 8:39 pm
Oh yeah, it was getting very annoying. I've treated all the doors as a precaution.
I guess it's like a trailer when the towball isn't greased, that can get very creaky.
Glad it's gone now, you really notice the difference.
Andy
Magwa
Post by Magwa » Mon Jun 09, 2008 4:12 pm
I thought mine was creaking but it was a plastic kinda sound.
I took a look at the driver side of the dash and next to the door found some loose plastic wedges ( as used in double glazing window fitting) pushed them back where they belonged and
Hey presto
No creaking
try your dash area first!
I just put back a previous owners fix and it works!
Good luck =D>
Live long die oblong
