Window not opening
M&K
Window not opening
Post by M&K » Wed Jun 04, 2008 5:46 pm
Hi Folks,
I have removed the door panels ( 2 or 3 times ) to replace the speakers, but now the passenger window will not open
either from the passenger door switch or the drivers switch,the connection in the door appears ok, there is a votage
at the connector inside the door and the drivers window work fine, all windows are on one fuse so i.m a bit puzzled, has
anyone had this sort of problem ?
Cheers , Mike.
westonwarrior
Re: Window not opening
Post by westonwarrior » Wed Jun 04, 2008 5:48 pm
there is a lock switch just under the 2 window switches on the drivers door have you knocked it to lock? as that will stop the passenger window as you describe.
hope its that simple
M&K
Post by M&K » Wed Jun 04, 2008 6:30 pm
I could lie but even though i feel like a DH i'ii own up, I never gave that switch a passing thought,
thanks Rob , you've saved me hours of pointless labour.
All the best , Mike
westonwarrior
Post by westonwarrior » Wed Jun 04, 2008 7:39 pm
No worries its one of those things that crops up from time to time and will again very soon
Thats why I knew about it
There should be a list of common things that happen and their simple remedies
Roof not going up = Hand brake not on
passenger Windows = switch locked
side door not opening from inside = Childlock
And many more that escape me
