bmw clock
bmw clock
Hi All, Just fitted clock with help from site it came without connection plug managed to find a non bmw on which fitted, i wired it up as follows( looking at clock from back) to radio loom LH pin to red wire, centre pin to black, RH pin to orange will only work when key in acc position, advice much appreciated
many thanks steve
many thanks steve
Re: bmw clock
I got lucky and found a permanent +ve feed going to my radio head plug (no I'm not and A&R man promoting the band). I found an ignition only +ve feed for the light there also, but no convenient sidelights on +ve feed for the clock light, so my light is on whenever I drive. Looks good when you drive into shade though (well that's my claim anywayribbleman wrote:Hi All, Just fitted clock with help from site it came without connection plug managed to find a non bmw on which fitted, i wired it up as follows( looking at clock from back) to radio loom LH pin to red wire, centre pin to black, RH pin to orange will only work when key in acc position, advice much appreciated
many thanks steve
Re: bmw clock
Thanks for reply clock up and running
thanks
thanks
Re: bmw clock
Goodo - well done
If not done already, you should treat yourself to an aluminium ring to go round it. Finishes it off a treat. £7 odd from BF member Haydn Callow (he usually lists them on ebay)
Re: bmw clock
I got the impression from your avatar you were a high flyer on the music scene...??mikeonb4c wrote:I got lucky and found a permanent +ve feed going to my radio head plug (no I'm not and A&R man promoting the band). I found an ignition only +ve feed for the light there also, but no convenient sidelights on +ve feed for the clock light, so my light is on whenever I drive. Looks good when you drive into shade though (well that's my claim anywayribbleman wrote:Hi All, Just fitted clock with help from site it came without connection plug managed to find a non bmw on which fitted, i wired it up as follows( looking at clock from back) to radio loom LH pin to red wire, centre pin to black, RH pin to orange will only work when key in acc position, advice much appreciated
many thanks steve)
Re: bmw clock
Groan...time for bed
These days - and I'm not kidding unfortunately - I just feel like a knackered old git
Re: bmw clock
just got a bmw clock for my bongo, came without a plug, does anyone know which pins are which?( L-R if looking at it from the back)... cheers
- missfixit70
Re: bmw clock
- westonwarrior
Re: bmw clock
yes i do thanks,,
there is a post about it from Hayden i will be looking for it as we speak
never mind beaten to it
Re: bmw clock
thanks guys i knew the info would be here somewhere...
