Slybacon wrote:Drained coolant and checked stat - seems to be opening fine. I didn't have a thermometer but it opened in the pan just before the water started to boil and bubble - so my guess is that it is okay.
Next job will be to flush system. I'm going to have a wee search on the forum for the best method first. If anyone has the time to give me some advice I'd appreciate it though.
I used a slight variation of the see saw method. I did not have a funnel so I used a big pyrex jug with coolant in it. I put the end of bleed hose below the surface. With the engine running, and the header cap off, I kept lowering the jug so that coolant ran into the jug, bringing air with it, then lifting the jug so that the coolant siphoned back into the engine. This has to be done until the thermostat opens and by that time the coolant is very hot so you need to be careful.
When the bubbles had stopped coming out I raised the jug to siphon most of the coolant back into the engine. Then I added some cold water to the jug so it was cool enough for me to put my hands in and pop the bung into the end of the bleed hose.
Then I went for a blast, keeping a close eye on the guage - no problems.
Then, using the idea that any small amount of air in left the system would have collected at the top of the engine, I left it overnight, and did it again first thing the next day with the engine cool and not running (a five minute job). I got out a few very small bubbles.
I did it all single handed, but it would have been easier with two folk.
Next time I do it I'll arrange a method to hold the jug at a height about the same as the header tank so i can rev the engine more easily. Sly, if I had taken out the stat, I would have put a new one in - thats on my list of things to do.
Hope this helps
Dave
